04-12-2019, 06:47 PM
#46
Originally Posted by JWaldz
What's this lens you speak of? I'm guessing the cover that goes over the lights and around the controls, for you non sunroof guys.
It’s the lens hopless diamond posted the part number for.
Now to go over the wire changes needed for converting my dual switch sun roof controls to the newer single switch.
I have a local dealer who’s prices are good so I’ll drop by and order the lens. I’m also thinking about updating the maps on the 2013 Toyota Corolla nav radio I installed.
04-13-2019, 07:41 AM
#47
Originally Posted by Hopeless Diamond
Yep, that's where I'm at too. Camelback does have them, only ~$13. Holding off on it till I need something else, it's about $10 in shipping just for it. Also need a donor harness so I can rewire the controls.
This site has so much great technical info, would never have gone through the process to figure out the wiring on my own. Of course, now I have yet another partially completed project...
Thanks for the reminder I need part of the harness. Or I need the connector and repin my wires to it so the sun roof works
04-13-2019, 06:12 PM
#48
Step 1. Parts collected
@ Sloweuroll
Thanks for making the mounting plate
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
04-15-2019, 06:51 PM
#49
Newly designed 3rd Gen Scangauge mount
I just ordered the 99 on up rear view mirror. I’m really wondering what the difference is between mine and the newer years. Like can I just cut stuff off the old mount?? I got two 96-98 mirrors. However, I ordered a newer style.
I thought about going junking looking for the mirror and possibly a newer style center console. But my local You Pull It yards have zero to 3 4Runners at any given time and they are usually the 96-98 and high milage with the rear suspension rusted off and 250k miles.
04-15-2019, 07:42 PM
#50
Real Name: Leon
Real Name: Leon
The mirrors themselves are identical, the mounts are different between '99+ and pre-'99.
If you ever need a small part like that, just ping me, the yards here are full of 3rd gens.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
04-16-2019, 07:31 AM
#51
If the 99+ mount bolts to the same holes as the 96-98 mount does too me some metal removal might work. However, I have one on the way.
04-16-2019, 06:32 PM
#52
Moderator
Real Name: Waldo
Moderator
Real Name: Waldo
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
04-16-2019, 08:43 PM
#53
Real Name: Chris
Real Name: Chris
I must be searching wrong. Can you point me to one?
This is the seller I purchased from.
https://www.ebay.com/usr/partsbroker...p2047675.l2559
04-16-2019, 09:45 PM
#54
This is rad!
01-22-2020, 11:38 AM
#55
so whats the deal with this? i read through this entire thread and i cant find a FMU. i have no desire to try and track one down and then get bent over on price. i just tried to look on ebay and couldnt find any.
was the other option ever released for the USDM sunglass holders? im sure there are some pics in this thread but i cant see any of them at work. btw, its more like a biz card holder. there is no way you are fitting a pair of sunglasses in mine.
i may just draw my own solution and print it myself.
99 4runner limited; imperial jade mica
IG: mesooohoppy
01-22-2020, 11:53 AM
#56
Real Name: Leon
Real Name: Leon
I have an FMU in my garage looking for a home. I bought it to do this mod, but then decided against it and designed my own mount for the scangauge. I believe the one I have is brand new, but I'm not completely sure.
01-22-2020, 04:56 PM
#57
4Runner leon has graciously offered to sell me his, but the problem is we dont know if the sunroof switch and the overhead lights are a direct plug in play in a 99 limited. can someone help us?
i know nothing about wiring and i dont want to start cutting stuff off my harness. id prefer to have the scan gauge up higher and out of the way.
IG: mesooohoppy
01-22-2020, 08:15 PM
#58
Real Name: Leon
Real Name: Leon
I looked at the back of the FMU housing, it looks identical to the 99+ console. I can't imagine it's not plug and play, especially since other folks on this thread have done this swap, and have not mentioned having to rewire anything.
01-22-2020, 08:29 PM
#59
Sunroof wiring changed between '96-'98 and '99-'02 trucks... but there are write-ups on how to make the changeover. The FMU's match the early style wiring, as far as I know, but mount like the '99+ glasses console.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-22-2020, 08:53 PM
#60
Real Name: Leon
Real Name: Leon
The FMU housing I have has identical connectors to the later style consoles, a single blue connector instead of three white ones of the '96-98 models. It'd be plug and play for 99+ models, but would need mods for '96-98 models.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
