Old 04-04-2019, 04:52 PM #1
TrexRunnerGirl's Avatar
TrexRunnerGirl TrexRunnerGirl is offline
Real Name: Teri
TrexRunnerGirl is on a distinguished road
Real Name: Teri
99 Power steering pump
I had some work done on my 99 while I was out west and come back and the power steering - or a hideous noise on the left front side when turning seems to be the issue.
They said they had to move it when putting on the tensioners (I had the TB/WP done) and now it sounds like shit and horrible noise when turning. I'm thinking power steering pump?
Any other ideas?
If the power steering pump, what do you guys use?
I've seen the ones from Rock Auto and it's w/o a reservoir so does that need to be included also.
Give me the skinny on what's up and what I need to get to fix it back to normal.
Thanks!
99 Limited Silver/Tan 145K, Love this old thing.
16 Sonata Sport, Red with Grey interior.
TrexRunnerGirl is offline   Reply With QuoteReply With Quote
Old 04-04-2019, 05:20 PM #2
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
I'd first check your fluid and see if it is low. If not, you'll probably need a new power steering pump. The reservoir is pretty simple to pull off and clean out. I bought a pump from rock auto and it seems to be holding up ok.
APhelps is offline   Reply With QuoteReply With Quote
Old 04-04-2019, 05:35 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You can try cleaning the screen in the pump reservoir and flushing the power steering fluid. It calls for Dexron 3 transmission fluid for the power steering system.
Old 04-04-2019, 05:39 PM #4
Real Name: Teri
Real Name: Teri
Which pump you get? Acdelco was the one I’m looking at. Plus seals n all that.
Old 04-04-2019, 05:55 PM #5
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
with the engine running, open up the power steering pump reservoir and make sure fluid is circulating. Also check to see if it's foamy and/or a lot of bubbles. If it is foamy, they could have knocked the reservoir enough to mess up the seal and it's letting air in (and leaking fluid that you haven't noticed yet).
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 04-04-2019, 07:01 PM #6
I bought the A1 Cardon, remanned one without a reservoir.
Old 04-04-2019, 08:04 PM #7
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Seems an awful coincidence that your power steering pump went out while a shop had it. Failing pump wouldn't be my first suspicion. I'd make sure they didn't do anything funny.
But then again, I am pessimistic and I have had shops break things for me.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 02:31 AM #8
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
If it's the whirring/whining noise you're hearing, try cleaning the screen in the bottom of the reservoir. If it's a high-pitched squealing, that's a belt slip/jammed pulley issue.
pluton is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 07:53 AM #9
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Doubtful its a power steering pump failing. They make horrible noise when fluid has trouble passing or air in line. If you've ever heard loud old water pipes in a house, same idea, that's air in the pipes. Those guys messed with it and produced the issue. I had same same thing, after a flush it went quiet. Also make sure all connections are tight.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 09:31 AM #10
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Any other ideas?
Thanks!
I did this as PM and what little noise I had a full stop disappeared. She's as quiet as a church mouse now
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 04-05-2019, 12:14 PM #11
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
A few tips before you go and replace it:
1. Check to make sure the belt is tight. If you press on the belt it should give a little but not anything significant. Check the tension compared to the other belts.
2. "Bleed" the steering by turning it from full lock on one side to the other, about 5 times slowly. This allows air to make its way out of the lines.
3A. After bleeding the system, open up the reservoir and check the fluid level on the cap. Refill as needed.
3B. If the fluid was low, check the boots on the inner tie rods for leaking fluid. After a long wheeling trip it's possible they sprung a leak.
4. If the system is still making noise, clean out the filter.
5. O'Reilly's sells synthetic Asian vehicle power steering fluid. Not everyone will agree with using it but it quieted up my power steering pump completely for $10. Extremely satisfied with the product.
6. If you still have the noise, replace the pump.
326WHP 347TQ
Old 04-05-2019, 12:26 PM #12
I'd venture to guess that if you have to clean out the reservoir due to trash something in the system has degraded to warranty replacement. Its a closed system not open to atmosphere so metal shavings are either coming from the pump / rack.
Old 04-05-2019, 12:35 PM #13
Real Name: Teri
Real Name: Teri
I'm sure Timmy the Toolman has a video on how to clean out the steering pump reservoir right?
I don't know if I have the right tools to do it. If there's some links in here that y'all can find for a novice like me to do it, please post it up so I can follow along.
Yea, it makes me quite unhappy (think unhappy Marine) that this issue has popped up 'suddenly'. I just wanted to drive it around and look cool. LOL
I have to ditch my Sonata now and I need something to drive.
Old 04-05-2019, 12:58 PM #14
Real Name: John
Real Name: John
Did you read my post?
3rd Gen T4R DIY Maintenance, Repair and Modification Videos
Old 04-05-2019, 02:26 PM #15
Real Name: Teri
Real Name: Teri
talk about a shaft job. the mechanic is telling me the pump is $435 alone. I about choked and said, naw I'll source my own.
Now I'm really getting annoyed with WTF is going on and what the hell did they do.
I'll watch the video and read up some more and try this on my own first.
noise , power , pump , steering , turning
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
How to: v8 Power steering pump zopperman 4th Gen T4Rs 14 11-02-2019 09:44 AM
1st gen power steering pump iBison For Sale: T4R Items 0 09-28-2014 12:04 AM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
