Old 04-20-2019, 02:22 PM #31
thewaydown thewaydown is offline
thewaydown is on a distinguished road
Still haven't pulled the spark plugs, but after driving it around for a couple of days, there are no leaks anymore.
So, no more coolant leaks, and I now have cabin heat. Those were my two symptoms and I can totally see how that looks like an HG issue, but im feeling pretty good that I've fixed the problem.
Thanks again to everyone for your input, couldn't have done it without you.
I'll still be pulling the plugs and looking for coolant. I might consider doing a leak down test either way, but I've never done one before so I'm not too sure of the ins and outs. I'll watch a few videos and read a little and make a decision.
thewaydown is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 07:02 PM #32
ztphillips93 ztphillips93 is offline
ztphillips93 is on a distinguished road
Possible bad heater core, does it smell in the cabin? also, try flushing heater core. look up the video by chris fix on yourtube
ztphillips93 is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 09:25 PM #33
I pulled the plugs today and put a borescope down each one. These are the pictures I got. None of them looked like what I would expect them to look like if coolant was leaking through. No wetness or cleanness. Keep in mind, this engine has 220,000 miles on it. I did notice that the plugs were single ground and not double as the manufacturer recommends. I'll be replacing them with double ground plugs (unless advised otherwise).
Here are the pictures, what do you think?:
No cabin heat + hose leaks-190420_175629-jpg  No cabin heat + hose leaks-190420_173054-jpg  No cabin heat + hose leaks-190420_170152-jpg  No cabin heat + hose leaks-190420_174625-jpg  No cabin heat + hose leaks-190420_164011-jpg  No cabin heat + hose leaks-190420_170140-jpg
Old 04-22-2019, 08:29 AM #34
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
When I inspected my cylinders/plugs on my engine that had a bad HG, I bore scoped them and they all looked pretty much the same. The leak down test is how I knew for sure I had a blown HG on the #3 cylinder.
I would just top off your coolant and keep a close eye on your coolant level now that you have your leaks fixed. If your not having any other symptoms of a bad HG, it's probably fine.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
cap , coolant , hose , radiator , system
Preventing coolant leaks at the top radiator hose... ShooterMcGavin 3rd gen T4Rs 15 05-17-2016 01:01 PM
V8 Radiator Hose - Silicone hose replacement? t-rex grrr 4th Gen T4Rs 3 10-16-2015 12:14 AM
Cold heat coming out but auxiliary heat? Gremcat Classic T4Rs 4 11-19-2014 09:57 AM
Problem - Missing Hose and Loose Hose Splashsky Classic T4Rs 2 04-07-2014 06:06 PM
Heat coming into the cabin from the rear window? yellowssm 4th Gen T4Rs 7 10-14-2011 03:17 AM
