Old 01-05-2020, 03:02 PM #16
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I had forgotten that I was able to spin the crank when getting to the connecting rod nuts. You will will need to be able spin the crankshaft so get as big a cheater bar as you can on the crank nut. A pry bar against the crankshaft counter weights won't hurt anything either. If you pull the spark plugs shoot some motor oil down the cylinders this may help. If you see any rod caps or main caps with any bluing or material sticking out of them try to uncap them. If the engines locked up you can not hurt it as it's a boat anchor any way you maybe able to salvage the heads.
plcfcng is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 04:30 PM #17
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
And I uploaded the wrong video...
This is the right one.
YouTube
Sent from my ONEPLUS A6003 using Tapatalk
Bucket81 is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 06:23 PM #18
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
I can see the flex plate move a bit you could place the transmission in neutral and have the wheels off the ground if there is a problem with the Transmission this could help. But if the Transmission shifted ok when the engine went bad then I doubt the transmission or converter got damaged. If you can look at all the rods and make sure that none are broken bent or in the way. Try turning it any way you can to get to the 6 converter bolts. If someone uses a pry bar on a rod journal while some one pushes on the crankshaft nut that could give you extra force. I had a 3.4 that threw a couple of rods I had to disconnect the rod cap and was able to push the piston up into the cylinder to get it out of the way. Maybe doing this with any disconnected rod will help some of the resistance making it so you can turn the crankshaft.
after relooking at the video I see the cast iron web moving so I think the engine is still locked and the Trans is as good as it was when the engine went bad. Again do what you can to get the rods that are disconnected out of the way push the pistons up into the cylinders sometimes the rods get in the way.
You could take the time to remove the cylinder heads it's a few hours more work but that way you can see down the holes to see whats going on. You can take the nuts off any rod you can reach the other one maybe back off what you can just keep an eye that those nuts that are loose don't get in the way.
Old 01-06-2020, 01:19 AM #19
Dieselchessy Dieselchessy is offline
Dieselchessy will become famous soon enough
Looks like maybe you spun a main bearing and welded the crank to the main bearing cap(s).
Might be able to free it with use of a hammer.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof.
Dieselchessy is offline   Reply With QuoteReply With Quote
auto , motor , pull , seized , transmission
Auto-Zone: Clearance on Motor Oil nissanh General Discussions 1 01-10-2017 07:41 PM
Seized Motor can it be fixed? 123preston123 3rd gen T4Rs 2 08-03-2016 12:42 PM
Antennae motor - pull or not? badhabt Classic T4Rs 4 11-19-2011 07:18 AM
Is there a fuse I can pull for the antenna motor on my 99 ltd? lbrowne Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-04-2008 01:34 PM
Copyright © 2019
