Originally Posted by 19963.4lsr5
I bought the longer Husky 1/2 " torque wrench from home depot. The extra length comes in handy on big hub nuts and crank bolts.
My 3/8" one stopped klicking at any setting so I need a new one. I'm looking at the AC delco digital one
I'll check the Husky version out. Was the 3/8 one that broke a Husky? My 3/8 HF stopped clicking too.
Originally Posted by Roamed YT
All hail the highway robber!
Snap-On Techwrench 12.5-250lb
But if you want to save some cash for other things... then I'd go with something like a Husky. I have a similar version of this and works fine for what I need. If I need something more accurate then I have access to that.
I think I'd have to sell a kidney to afford a $500 torque wrench!
Thats two for Husky though! I like some of their ratcheting wrenches, but never used their torque wrenches.
Originally Posted by hounddogman
This is certainly a possible!
Originally Posted by OneOffStroker
Up until two years ago, I ran a calibration lab for the Navy, and I was the mechanical gauge calibration specialist. Since I had access to the calibration tools, I ran MANY different torque wrenches through the ringer, including a lot of HF ones for myself and others. EVERY ONE OF THEM was spot on. Repeatable measurements time after time.
So for a 9.99 torque wrench, you cannot go wrong. Seriously.
But as far as a 250 lb-ft unit, they don't make one, so that's a no go.
I'm sure they are accurate when they work, but I've lost confidence in all HF torque wrenches after my 3/8 one stopped working. The 1/2 wrench I'll still use, if I have to, but I'm just ready to be done with HF in the torque wrench department. Plus as you already mentioned, they don't have a 250lb version.
Originally Posted by reelamin
I have used my SK for years and it has always been right on when I check it. I have not had to make one adjustment for over 15 years. I just swapped out 5 full sets of summer tires and every winter wheel was as when I put them on.
I've heard good things about SK in general, so I'll be looking into their torque wrenches.
Originally Posted by LittleCaesar
Kobalt at Lowes. Can find them sometimes on sale for $60.
Also get yourself a 1/2" 16" breaker bar for the bump start method. If you need to remove the AC bracket bolts get a 14mm stubby ratcheting wrench.
I saw these at Lowes and definitely liked the price! This is a top contender for both the price and good reviews. And I'll definitely be doing the bump start method with a breaker bar as I'm much too lazy to get all crafty and build a tool for it.
Do you only need to remove the A/C bracket if the hydraulic tensioner is being replaced? I read the write-ups a while back but can't recall all the little details. Guess I better go read them again...
"Variety is for your mind, not your body " —OS
