Old 07-03-2019, 10:13 AM #31
Joelzy's Avatar
Joelzy Joelzy is online now
Joelzy is just really nice Joelzy is just really nice Joelzy is just really nice Joelzy is just really nice
Joelzy's Avatar
Originally Posted by Fadiddy View Post
Btw, if I can give any advice to anyone looking to take this kind of a job on....bag and mark EVERYTHING. I can't even begin to tell you all how much money and stress it has caused sourcing the small $hit.
YUP! hell, even then i still misplaced a few bits and some were never there thanks to the PO pulling the motor out and just throwing things in a box.
Taking a lot of extra time to clean, bag and tag is top of my list for the next motor build... as well as getting it as clean as you have
Ė96 SR5 5SPD Elocker "the Barnacle"
Ė02 bmw 540i6
Ė19 Highlander SE
Joelzy is online now   Reply With QuoteReply With Quote
Old 07-03-2019, 03:09 PM #32
19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice 19963.4lsr5 is just really nice
Funny you say that itís similar to how I ended up with my 97 SR5. He had the engine half torn apart for head gaskets and got a DUI and ran out of money and it sat for almost a year. Things were in boxes in the back.
Old 07-04-2019, 05:37 PM #33
Fadiddy Fadiddy is offline
Fadiddy is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
I bagged and tagged everything and still couldnít find my rear main seal plate bolts.
I do not like the one second for the oil pressure light to go off after engine run.
It also seems like I have a tick in the passenger side head. I had to use the intake cams from a different head. If it was cam bearing noise this engine would be dead by now. I got 4500 miles on the fresh engine. With the engine tick at idle.
It may also be wrist pin noise. I know Iím done worrying about the noise. Oil is clean with no metal visible. And at 4500 miles it was still hard to see it on the dip stick. I did the alternative break in method. As soon as I got it running I did around 15 30-60mph 3/4 to WOT accelerations and around the 30 mile mark I ran it up the mountain hard. Those rings are bedded in for sure.
I did bead blast the exhaust manifolds and the intake manifold and intake plenums to make it more presentable.
Wow, interesting. I'm wondering if the ticking noise was from the valve bucket shims. My machine shop told me they re-checked all shims, and two shims from both heads were out of spec. They simply moved them around, and got everything to sit even within spec. The machinist did say, that if I would have kept those out of spec shims in place, the motor would still run...except it would have a loud ticking sound.
Right? Man, I got nuts and bolts alllllll over the garage now. I have no idea where half of those nuts and bolts go now....lol. I mean, they are mostly for brackets and non-mechanical items, but damn....I haven't the slightest clue where I originally pulled them from. I am slowly buying and sourcing new or "newer" nuts and bolts just because the old ones are in terrible shape.
Fadiddy's Build Thread | 2000 Limited 4x4 | e-Locker | ARB Bumper | IPF Lights | Tundra TRD Front Coils & OME 890 Rear Coils | Bilstien 5100 Shocks | Tundra Brake Upgrade | Spidertrax 1.25" Spacers | 285/75R 16 General Grabbers AT2's | Toyotec Bump Stops and Diff Drop | E7006 NAV
Fadiddy is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 06:20 PM #34
Fadiddy's 5VZFE Build
When I bought the dead SR5 I pulled engine and put it on a stand and didnít touch it. So I had good reference to bracket locations and bolts for them as well as all the intake and intake plenum bolts. What I couldnít find when I put the engine from the wrecked 96 in the maroon 97 I robbed from the dead motor I pulled out or from the engine bay of the wrecked 96.
Itís a lot of reading but that whole journey is documented in my 97 SR5 Build and Repair thread.
Old 07-09-2019, 12:03 PM #35
Some more progress....
Old 07-18-2019, 06:01 AM #36
Does anyone know if the coolant pipe in-between the two cylinder heads (in the center of the block) that leads to the firewall inlet and outlet of the heater core has an o-ring, gasket, or sealer?
Thanks.
Old 07-18-2019, 09:35 PM #37
SilverRidgeRunner1's Avatar
SilverRidgeRunner1 SilverRidgeRunner1 is offline
Real Name: Justin
SilverRidgeRunner1 is on a distinguished road
Real Name: Justin
Thanks.
Its sealer
SilverRidgeRunner1 is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 10:06 PM #38
Roc Doc's Avatar
Roc Doc Roc Doc is offline
Roc Doc is on a distinguished road
Roc Doc's Avatar
That's exactly what my engine looks like...not.
Looking good!
1998 4Runner Limited, King coilovers, Trick Toys Fab front bumperette/lightbar, TTF rock rails, Toyo 265's, locker mod.
Roc Doc is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:12 PM #39
BostonJon BostonJon is offline
BostonJon will become famous soon enough
Originally Posted by SilverRidgeRunner1 View Post
Its sealer
Just replaced the water bypass pipe on mine about a month ago. It uses the black FIPG material. There is a small grove on the pipe mating surface for the sealant.
BostonJon is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:12 PM #40
And donít forget an oil filter
Old 07-22-2019, 11:42 AM #41
Its sealer
Thank you sir!
Looking good!
Hehe...thanks bud. I hope all this "pretty paint" holds up.
Thank you!
Hopefully not, lol.
Old 07-22-2019, 11:48 AM #42
Got my fuel injectors fully cleaned and tested. If anyone wants a good shop that does this, give Fred a call at Rosch Fuel Injection Cleaning. Excellent service and quick turn around. He cleaned all injectors, replaced all o-rings, replaced all filters inside the injectors, and tested spray pattern and coils. Excellent service for a great price!
Here are some more pics of the fuel rail and injectors installed:
Old 09-06-2019, 04:55 PM #43
She is ready to go back in fella's....about damn time right? Lol.
I ordered some new bolts for the flexplate, but should be ready to go in tomorrow. Here is the engine all prepped up to be installed:
Also found a fantastic transmission cooler from the junkyard off of a VW Toureg that fit really nicely in the front. Win!:
Old 09-06-2019, 07:03 PM #44
T4topher's Avatar
T4topher T4topher is offline
T4topher has a spectacular aura about T4topher has a spectacular aura about
T4topher's Avatar
Thank you sir!
Thank you!
Hopefully not, lol.
Hey just a heads up Iím sure the fipg is fine for that coolant inlet but it does take a gasket. During my timing belt job I replaced my inlet & outlet due to excessive corrosion on the aluminum and looked high and low for that gasket. Here is the part number if you want it 1634162040 also here is a link for the breakdown showing the gasket RADIATOR & WATER OUTLET | 4RUNNER VZN185L-GKPGK KZN185,RZN18#,VZN18# | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 12:47 AM #45
Yep, I got a gasket for it and put fipg on both sides. Actually put fipg on most of the gaskets on this motor, even if Toyota doesnít call for it. Iíve done this on previous 2JZ builds and have never had leaks.
cylinder , engine , injector , leaks , motor
Fadiddy's 3rd Gen Build Fadiddy 3rd gen T4Rs 18 10-13-2016 12:59 PM
WTB 3.4L 5vzfe sbarn5390 Want to Buy/Trade 0 08-03-2016 09:39 PM
FS: 5VZFE Oil Pan and Fan nobb For Sale: T4R Items 0 11-18-2013 11:21 PM
Question about 5vzfe nissanh 3rd gen T4Rs 14 04-21-2013 08:56 PM
