Old 05-24-2015, 03:27 PM #1
GangsterOfLove's Avatar
GangsterOfLove GangsterOfLove is offline
Real Name: Steve
GangsterOfLove is on a distinguished road
Real Name: Steve
Heater Control Cable
00 4Runner, 4 cyl, auto.
Heater control rotary knob (the one that directs where the air comes out) is hard to turn. Have yet to take it apart but it feels like it connects to one or more cables.
Do I replace the cables or is it possible to lubricate them? Or is there something else that commonly goes wrong?
Thanks!
GangsterOfLove is offline   Reply With QuoteReply With Quote
Old 05-24-2015, 09:13 PM #2
nissanh nissanh is offline
It is a metal wire and not a cable. It never gets jammed. Remove the knobs and gently lift the AC switch off the unit. There should be 2 philips screws and you should be able to pull the control unit few inches. Now you can find the cable. There is a metal clip that holds the outer cable housing. Put a mark on the housing cable and remove the clip but don't let it fall into the dash. You can now remove the cable. NOTE: put back the clip right on the mark other wise the doors won't close and direct the air properly
The other end should be visible from the driver side gas pedal
Old 05-24-2015, 11:02 PM #3
Real Name: Steve
Real Name: Steve
Thanks very much!
Old 11-23-2019, 09:40 PM #4
AZBub's Avatar
AZBub AZBub is offline
Real Name: Chris
AZBub will become famous soon enough AZBub will become famous soon enough
AZBub's Avatar
Real Name: Chris
I know this is an OLD thread but I had a hell of a time finding the part number for the water valve control cable. The part is 55907-35080 if anyone needs it.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
AZBub is offline   Reply With QuoteReply With Quote
Replacing cable for heater control valve mike_m 3rd gen T4Rs 17 04-02-2024 10:00 PM
Cruise control cable bolt size 90_4RunnerRLH Classic T4Rs 4 02-15-2013 11:04 PM
WTB 3rd GEN Cruise Control & Cable/wiring SummerallGuard04 Want to Buy/Trade 5 08-23-2012 05:27 PM
A little help please- heater control cable kezar Classic T4Rs 6 05-06-2011 11:49 AM
Cruise Control cable TaubBaer Classic T4Rs 0 11-19-2005 05:24 PM
