All, I just picked up my first 4Runner and could not be more excited. After looking everything over, I know I need to take care of a seeping valve cover gasket and also a seeping tranny oil pan gasket.
I have been reading all over the forums and discovering how to do the valve cover gasket on my own. My parts list is below. My question is, what tools do I need? Also, is anyone in SoCal willing to help me out? I would provide the food, drinks, and parts
In addition to the items below, should I replace the spark plugs? What about the cam seals, is that possible? I have 139,000 miles on a 2002 SR5.
My order consists of :
1-PCV Valve, Part #12204-62010 Might as well replace it while I'm doing this
1-PCV Grommet, Part # 90480-18001 Just in case the old one is in bad shape
2-Valve Cover Gaskets (both the L & R side are the same part), Part #11213-62020
6-Spark Plug Tube Gaskets, Part # 11193-16010 No need to replace as of yet but it is recommended
2-Intake Plenum Gaskets (both the upper & lower are the same part), Part # 17176-62040
16-Washer Seals (for the valve cover bolts) Part # 90210-05007 While I'm at it, might as well change them
2 Camshaft housing plug: 11188-62010
1 FIPG: 00295-00103
For the transmission, it should be easier. Pull the plug and drain everything. Drop the pan, remove sealant, put silicone, place new gasket and replace pan, correct? Should I put a new filter in? What parts do I need for this?
How can I clean the engine off and the undercarriage off?
I am concerned one of the O-Rings might be bad, but I am not really sure how to take care of it.
THREE PICS:
1: Valve Cover Driver Side
2: Valve Cover Passenger Side
3: Transmission Pan... grimy. How can I replace the O-ring in right?
Thanks guys. So far, the people on this forum have been great.
-John
