Old 04-11-2019, 09:54 PM #1
RockyrT4R's Avatar
RockyrT4R RockyrT4R is offline
Real Name: Christian
RockyrT4R is on a distinguished road
RockyrT4R's Avatar
Post +3.5 Long Travel Designs and Plans!!
If you are interested in building your own long travel suspension you have come to the right place!!
I am providing 3rd Gen 4Runner and 1st Gen Tacoma owners who have fabrication experience or someone who can build it for them plans and designs.
These Plans Include:
-DXF Cut Files for Flat Parts
-Dimensioned and Labeled Part Diagrams
-Parts List, Includes all necessary part numbers, details and specifications for necessary components.
-Build Order of Operations
-And More!
Benefits of this Long Travel setup:
-NO MORE LOWER BALL JOINT FAILURES!
-13” of travel achievable without CV modification.
-All joints are Uni-Ball Joints, which are much stronger than a conventional ball joint.
-Heavy Duty Hiem Joint Steering Linkage
-Works with:
96-02 4Runner 2wd/4wd
95-04 Tacoma 4wd
**These plans are for experienced fabricators**
-If you are not comfortable fabricating, it is highly suggested that you take this kit to a professional fabrication shop.
The Designs, Cut Files, Dimensioned and Labeled Part layouts, Parts list w/ references and build instructions are all included for the price of $200.
These are still in the development phase but most of the large issues have been worked out.
DM me to inquire about more information or purchasing your plans!
Here's a picture I grabbed a little while back!
(In the picture I was running Tundra Bilstien 5100s but I have switched to 2.5x8" Coilovers with Reservoirs now.)
+3.5 Long Travel Designs and Plans!!-15933025-6a75-46c3-9c4d-55db4389f4cd-jpg
Owner at Sawtooth Offroad Fabrications | 99' LTD V6 Millenium Silver w/E-Locker | AOR Bumper | “Bandit” Dual Swingout Rear Bumper | SlimsDepot 55w 6000k HID’s | 315/75R16 Falken AT3W
Instagram: @rockyt4r
RockyrT4R is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 02:17 PM #2
OU4x4's Avatar
OU4x4 OU4x4 is offline
Real Name: Eric
OU4x4 is on a distinguished road
OU4x4's Avatar
Real Name: Eric
without giving away state secrets...how do you get long travel with no CV mods?
other kits require longer CVs
2001 Toyota 4Runner SR5 4x4
3" SS lift
285/75R16 Cooper Discoverer ATP
Outdoor Logic Front Bumper / Savage Off-Road Rear
Visit my garage for the full list
OU4x4 is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 09:08 PM #3
Nate_GB's Avatar
Nate_GB Nate_GB is offline
Nate_GB is on a distinguished road
Nate_GB's Avatar
It uses tundra axles.
Nate_GB is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 09:09 PM #4
ragingbull2k2 ragingbull2k2 is offline
ragingbull2k2 is on a distinguished road
Probably meant stock tundra axles.
Sent from my SM-G975U using Tapatalk
ragingbull2k2 is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 03:40 PM #5
RockyrT4R's Avatar
RockyrT4R's Avatar
Yes this uses 1st gen tundra cv axles, it is a direct fit and they are 3.5” longer so they are perfect for this length of long travel!
Old 04-15-2019, 05:00 PM #6
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Interesting. Most LT kits are way out of my budget, but I could probably borrow a TIG welder long enough to make these.
How to these compare engineering-wise to other LT kits? Would there be any differences in caster/camber/toe? Will these hold up (especially with the BJs and heims) to being on a DD?
Can you use a standard 3rd gen suspension setup?
I'd definitely be interested in these if a few more people put road time on them.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 08:38 AM #7
Autozone Special Autozone Special is offline
Autozone Special is on a distinguished road
Can you post a picture of the suspension setup to see how you kit looks and I'm wondering if this is still avaliable?
Autozone Special is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 02:21 PM #8
rics97toy's Avatar
rics97toy rics97toy is offline
Real Name: Rick
rics97toy is on a distinguished road
rics97toy's Avatar
Real Name: Rick
I am interested in the long travel plans if they are still available
rics97toy is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 02:29 PM #9
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Id like to see the front,, flex as the rear can flex pretty good already
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 02-11-2022, 01:30 AM #10
TACOMARHOADS99 TACOMARHOADS99 is offline
TACOMARHOADS99 is on a distinguished road
How do we go about getting this file?
TACOMARHOADS99 is offline   Reply With QuoteReply With Quote
Old 02-11-2022, 06:33 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
-And More!
-Works with:
95-04 Tacoma 4wd
At the risk of sounding like an ass, did you read the first post? I marked the important part for you.
Old 02-11-2022, 08:14 PM #12
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I would kill for an LT set up but I just can't bring myself to deal with squeaky uniballs
Old 02-12-2022, 09:45 AM #13
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
I’ve had my uniball UCAs for 5 years now
Minimal to no maintenance
No play
No squeaks
Has anyone put any real road miles on these kits. ?
I follow this build on ig and it’s at a stand still for now.
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
Old 05-18-2022, 02:08 PM #14
[email protected] Urielrg85@gmail.co is offline
Urielrg85@gmail.co is on a distinguished road
How can I buy them?
I'm interested in buying the files
Urielrg85@gmail.co is offline   Reply With QuoteReply With Quote
Old 09-20-2022, 01:15 AM #15
994runnerluke 994runnerluke is offline
994runnerluke is on a distinguished road
I’d like to buy your plans for $200 would you please email me at [email protected] or text at 916-4l7- 35 nine nine. Or get back to me here.
994runnerluke is offline   Reply With QuoteReply With Quote
long , part , parts , plans , travel
Plans to Travel Across the US Samedi 5th gen T4Rs 31 07-29-2021 01:13 PM
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
LED HID 4 sale (Rigid Baja Designs Lightforce) Long Beach CA 90720 n210wagon For Sale: Non-T4R Items 3 02-07-2018 07:36 PM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
Long Travel Tooltime19 4th Gen T4Rs 40 01-14-2015 10:05 PM
