Old 03-14-2013, 12:42 PM #1
teachme teachme is offline
teachme is on a distinguished road
Seat bolt came out .....
Hey guys I just bought a 1996 4runner and I am loving it. The frpnt drivers seat bolt near the door fell out. I got the bolt but it wont go back in its like a nut is missing off the back of it. Any help would be appreciated
teachme is offline   Reply With QuoteReply With Quote
Old 03-14-2013, 03:06 PM #2
shootmymime's Avatar
shootmymime shootmymime is offline
shootmymime will become famous soon enough
that sucks! i had the same thing happen to me. the nut is tack welded onto the sheet medal on the body for the car under the carpet. i snapped mine off when i was installing the seat back.
what i had to do is pull the carpet back up. reweld, glue, attach the bolt back in the place where it should be. then pull the carpet back and install the seat. being very careful not to snap the nut off the sheet metal again. i used an impact what has high revs to get my bolt spinning faster than what the nut will spin if it does brake off again. be sure not to torque it down very hard because you will pull the nut through the sheet metal.
its very tight space in there so take you time. if you get frustrated stop, step back, and get something to drink. then go back and look at how you can get it to work. good luck! i hate that problem.
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
shootmymime is offline   Reply With QuoteReply With Quote
Old 03-14-2013, 03:32 PM #3
Thanks for the advice. I got a super deal on the yota got if from a friend for 1500.00 runs great. Had to replace headlight assembly adjustment screws were broke. Loving ot so far
Old 03-14-2013, 03:32 PM #4
cordrayj1's Avatar
cordrayj1 cordrayj1 is offline
Real Name: Johnny
cordrayj1 is on a distinguished road
cordrayj1's Avatar
Real Name: Johnny
i was under the impression that there is a nut welded to the body from below. this doesnt make sense. go get a 12mm bolt, which can be found in many other places on your vehicle, and put it back in where it belongs.
and dont EVER USE AN IMPACT on something like that. thats lazy and an awesome way to break all sorts of crap.
2000 4Runner SR5, 5vz-fe, 5speed, 246k miles, bfg 35's on stock 1985 4runner wheels
cordrayj1 is offline   Reply With QuoteReply With Quote
Old 03-14-2013, 03:34 PM #5
I think the nut that was welded there is gone because the bolt spins and spins nothing to grab hold of
Old 03-14-2013, 03:35 PM #6
cordrayj1's Avatar
Real Name: Johnny
cordrayj1's Avatar
Real Name: Johnny
get up under the vehicle and look for it.
Old 03-14-2013, 03:36 PM #7
Would it be inside the cab ? The previous owner said this happened a few months back
Old 03-14-2013, 03:38 PM #8
cordrayj1's Avatar
Real Name: Johnny
cordrayj1's Avatar
Real Name: Johnny
pretty sure its under the car. if you look at the bolt hole its flush w the floor pan. its a common toyota design. the back seats that flip down are the same design w the nut welded to the underside of the body for a flush fit and finish
Old 03-14-2013, 03:40 PM #9
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The nut is tack welded on the INSIDE of the crossmember. I had the same thing happen. I cut a small rectangular hole on the backside of the crossmember with my Dremel just big enough to fit a pair of needle nose pliers so I could hold the nut and torque the bolt down. Worked like a charm!
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 03-14-2013, 03:45 PM #10
cordrayj1's Avatar
Real Name: Johnny
cordrayj1's Avatar
Real Name: Johnny
Old 03-14-2013, 03:58 PM #11
Ok cool ill look for it tonight thanks for the info guys
Old 03-14-2013, 04:38 PM #12
rjaudi rjaudi is offline
rjaudi is on a distinguished road
The front bolts are attached to a piece of sheet metal welded to the floor. Mine broke off and is just spinning right now, I will be having fun if the seat ever needs to come out. The rears go through the floor. I think I read the torque spec on those bolts is only 20 ft lbs or so.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
Old 03-14-2013, 05:40 PM #13
its not a 12 mm bolt to begin with. its like a 14.
i had to use an impact because mine was spinning with the bolt and i could not rotate the ratchet fast enough to crank the bolt into the nut without the nut spinning too.
from reading your posts from earlier, you are not clear on what we are talking about and how the nut attaches from INSIDE the cab. you are correct that the back seats and the back bolts on the front seats go through the floor. but we are talking about the front nut on the front seats.
SEE part #57452 there are 2 black holes on ether side of the 45 ish degree slant on the front. those are the bolt hols and the nut is tac welded on the back side of there. Teachme you are saying the nut is lost. that is because it has fallen down and it is in that channel some where. it is there. (nowhere else to go or fall out of the car) its trapped between 2 pieces of sheet metal.
Old 03-14-2013, 05:57 PM #14
Right I didnt know where the nut was but I know where to look thanks to yalls help
Old 03-14-2013, 08:16 PM #15
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
My fix was just to get a much longer bolt and drill a hole through the floor pan passing the bit through the bolthole. I then added a fender washer and a locknut from the underside of the truck. I'm pretty sure that it is stronger than the miserable nut on the top in thin sheet metal in the factory configuration. These bolts only get stressed in a rear collision; I suspect the seat back collapses first.
I think it was Brian that did this first; I just copied it.
My Backyard Frame Swap
WTB:3rd Gen-Need Drvr Side Seat Track (Pwr) or Full Seat RPC10022 Want to Buy/Trade 8 01-06-2013 05:17 PM
Wtb oak interior front passenger seat bolt cover 4runnerTiger For Sale: T4R Items 0 12-18-2011 10:18 PM
seat rail woes. my seat is a tripod! stupid rust. help? 4x4RunnerSR5 3rd gen T4Rs 6 10-13-2010 02:53 PM
Bypass seat airbag and seat belt lights? Recaro install steve germany 4th Gen T4Rs 0 04-04-2009 09:18 AM
driver's side seat-rail bolt cover swooopeno Problems & Warranty Issues 10 06-18-2005 10:26 PM
