Old 04-14-2019, 11:41 PM #1
kilowhisky kilowhisky is offline
kilowhisky is on a distinguished road
Horrible creaking on front right suspension
After a hard ride out in the desert with some water, mud, dust, and dirt my vehicle has started giving this absolutely horrendous creaking sound anytime i turn the wheels and anytime the suspension flexes on the right hand side.
I've been trying to figure out what it is for a while now and i'm stumped. I took silicon spray grease and went to town on anything and everything i could find that moves under there and the creaking has not gone away. I did find what appears to a broken boot on the lower ball joint but it doesn't appear to be spraying grease and filling it with lube didn't make it happen any less.
Here's a video of the problem.
YouTube
kilowhisky is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 08:18 AM #2
For me, the kid I bought my 97 project from had replaced the lower ball joints and tie rod ends.
I developed the creek on the drivers side. Same as you. Turning or just moving the suspension.
I looked at the lower ball joints and seen there were grease zirc holes. So I installed some and greases the lower ball joints. No more noise and steering is a lot easier to turn.
Old 04-15-2019, 08:58 AM #3
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
That is most likely the LBJ. My old ‘96 made the same sound intermittently for weeks before the driver’s side let go. The day it let go the steering also got tight. I wouldn’t drive it until you replace them.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 10:18 AM #4
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
No direct experience, but just looking at what it COULD be based on your video, LBJs would be my first suspect. When you're just sitting still and turning the wheel there are very few parts moving...LBJs, UBJs, tie rod ends, steering rack...that's about it.
Something you could try to help nail down the noise is use a 2-3' length of vacuum line. Hold one end to your ear and use the other end to probe around for the noise. It helps isolate and amplify noises that are hard to pin down. Also great for things like squeaky pulleys, exhaust leaks and engine ticks.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 10:48 AM #5
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I agree with what others have said. Since you did notice a tear in your lower balljoint boot and just did some desert wheeling, you might have just taken your balljoint to the edge of failure. Depending how long that boot was ripped, the joint might have been mostly dry and now add in some dry, sandy wheeling and you probably got some grit in there that accelerated the demise of that joint.
It's sound advice to leave your rig parked and replace your balljoints. It's not worth risking a failure that could cause significant damage to your rig and potentially cause an accident hurting you and others.
If you're willing to do this, jack up your rig and check for play in the joint and film it for us. But, even if you don't see play, I'd replace them anyway. Here's a video you can use for checking the play:
Here's a video you can use to swap out your balljoints. Do yourself a favor and buy Toyota OEM balljoints. Don't cheap out with aftermarket ones. You'll be sorry that you did.
mtbtim is online now   Reply With QuoteReply With Quote
Old 04-16-2019, 01:15 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Assuming it is safe to do so, you should be able to place a hand or finger on whatever part is making that loud of a groan and feel it.
pluton is offline   Reply With QuoteReply With Quote
Old 04-16-2019, 04:21 PM #7
Yea i did that, its all 'groaning'.
What's funny is that when i bought my 4runner i got on here and heard the horror stories of the LBJ failures so i did some preventative maintenance by changing them out... only have to one fail in 3k miles. Whoooooops. I'll be going OEM this time instead of o'reilly. Whats interesting is it doesn't look like the boot failed, it just... came unseated.. Like it is entirely intact, just not protecting what it should be.
I'll try the vacuum line thing. Its soo damn loud and high pitched i couldn't pinpoint where it was coming from.
Old 04-16-2019, 04:50 PM #8
Real Name: Evan
Real Name: Evan
In my opinion and my experience with the same issue, the groaning is from the either the ball joint stretching out the cup and being very close to pulling through or from missing all the grease from inside the boot or a combo of the two. By the time this noise happens you definitely need to address it right away. I’m not surprised an auto parts store LBJ failed fast but wow, 3k miles?!
Horrible creaking on front right suspension-a130cc73-9876-4052-b344-b4c0140f00c7-jpg  Horrible creaking on front right suspension-39daeb9d-ab58-4620-a036-4afc984b13f6-jpg
Old 04-16-2019, 06:10 PM #9
406-T4R 406-T4R is offline
406-T4R is on a distinguished road
lbj's
Was going to chime in but everyone has pretty much said what I thought. I just recently had the same noise and it went away after replacing my lbj's.
406-T4R is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 03:59 PM #10
JLStout JLStout is offline
JLStout is on a distinguished road
Mine was making a horrendous racket, even after I did my ball joints and tie rod ends. Ended up being the control arm bushings.
JLStout is offline   Reply With QuoteReply With Quote
Old 04-18-2019, 01:04 PM #11
phattyduck phattyduck is online now
If they have grease zirks, they are not OEM. If they made noise, they are about to fail. Replace with OEM ASAP!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 05-02-2019, 11:16 PM #12
Welp after the change the noise has gone away so i guess it was 100% the LBJ!
Interesting as it had plenty of grease still and the boot wasn't 'torn'. The ring locking the upper part of the boot to the top of the joint had come off and allowed the boot to slide down.
Got OEM from amazon for under 100$ and now i can't remember why i didn't go OEM before...
Old 05-02-2019, 11:32 PM #13
Outrider Outrider is offline
Outrider will become famous soon enough
After doing some reading over the last few days on LBJ failures, I have become really paranoid about mine letting go, at 195k miles. Driving down the road, I try to not stress them by turning while going over curbs, bumps, etc. I have been picturing my wheel letting go, and me going for a few rolls in my T4R.
I found that Camelbak will sell me all of the parts I need for $230 shipped, while my local Toyota stealership wants $350, and they don't even have the parts in stock. I will order them tomorrow from Camelbak, and probably replace them sometime next week. Then I can get paranoid about something else.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 08-31-2022, 12:42 AM #14
Jake.e Jake.e is offline
Jake.e is on a distinguished road
Was it the same noise as in the video he posted?
Jake.e is offline   Reply With QuoteReply With Quote
Old 08-31-2022, 12:45 AM #15
The lbj replacement got rid of that awful noise completely? My rig is making the same exact noise when i turn the wheel while parked. But i didn’t think it was the LBJs bc for preventative maintenance i replaced the old ones with new OEM ones and its only been 15k miles and they sound like that. Maybe off roading or something caused dirt or something to get in and cause them to fail. Very annoying to have to drop money on new ones already. Hopefully it takes care of the noise
anytime , creaking , find , grease , suspension
Creaking noise coming from drivers side suspension Silver.T4R 3rd gen T4Rs 30 09-02-2021 09:55 AM
Creaking front suspension.. mosovich 5th gen T4Rs 13 06-13-2019 12:44 PM
Creaking sound from rear suspension d0nkeyxpunch 3rd gen T4Rs 10 07-18-2017 05:10 PM
Horrible feeling in Front Suspension 03L4RUNNER 4th Gen T4Rs 7 07-18-2011 05:05 PM
Suspension Creaking DCT Engines / Suspension / Wheels / Tires / Audio / Accessories 3 07-02-2010 04:39 PM
