Originally Posted by Pekoe1111
I am just trying to remove the plug wire from the coil pack but can’t figure out how the clip works. I don’t want to force it and ruin the wire. Any tips or photos to help pick up this clip off? Thanks!
If you're referring to the wire that goes from the coil pack to the other spark plug I used a small pocket screwdriver and pried at the bottom of the clip while pushing down then pulling up to disconnect them. The clip is meant to be pinched at the top of the connector. Hope this helps
