Old 04-17-2019, 07:38 AM #1
Timjtitus Timjtitus is offline
Timjtitus is on a distinguished road
New clutch or new tranny?
I’ve got a 2000 4x4 v6 manual. 2nd gear has always had a grind to it especially once it warms up. I’ve changed slave and masters, clutch fluid, marlin heavy duty shifter seat, red line mt90. Now I’m about to change the clutch out but I’m considering ordering a marlin crawler rebuild since the transmission will already be our. Should I swap the clutch, throw out, pilot, clutch fork and whatever I can get to only or go ahead with the marlin tranny?
Timjtitus is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 07:43 AM #2
I’ve had the truck for 2 years and it has 190k
Old 04-17-2019, 08:42 AM #3
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Sounds like your syncro is shot. Common wear symptom, and you did everything possible to remedy it with out pulling it apart. Just needs a rebuild. In the mean time If you make a slower concentrated meshing effort on on the 2nd gear shift you can eliminate the grind while you drive it. You may have chewed up that gear, but you'll find out what it looks like when its torn apart.
Here's a pic of mine apart, so you get an idea on the gears.
New clutch or new tranny?-5-speed-w-125k-rebuild-may-2018-jpg
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 09:15 AM #4
That’s what I’m thinking. I can usually avoid the grind but I have to let the rpm drop below 1000 usually.
Old 04-17-2019, 10:14 AM #5
I_bRAD I_bRAD is offline
I_bRAD is on a distinguished road
Had no idea marlin crawler sold a rebuild kit for these things. And cheap! Thanks for the heads up.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
I_bRAD is offline   Reply With QuoteReply With Quote
Old 04-17-2019, 11:00 AM #6
I’m actually planning on ordering a rebuilt transmission. If I already had the tools id consider doing it myself.
clutch , i’m , i’ve , marlin , tranny
Clutch engagement point on pedal after new clutch and flywheel installed 89FourRunner Classic T4Rs 8 11-18-2016 04:03 PM
Clutch Replacement - Can't break tranny loose! denvermaxd 3rd gen T4Rs 6 05-14-2016 07:17 PM
Clutch Start fails AND tranny is almost impossible to get into gear. Coincidence? itgogitrev Classic T4Rs 7 02-28-2015 08:15 PM
99 4Runner 5spd clutch / tranny issue(s) davemw 3rd gen T4Rs 8 11-05-2011 12:30 AM
Tranny, Clutch & Rear Diff toast after 74K miles? Caffeine Power Problems & Warranty Issues 2 01-24-2007 10:49 PM
