Originally Posted by LittleCaesar
If you have ever replaced the front nozzles, the rear one is loaded with two little clips that must be pried out. I think I used a screwdriver and pick. It isn't the easiest to do, since you have to note the nozzle orientation. Check the check valve for the fluid tube to make sure it works first, it should be located under the rocker panel for the rear passenger side door. About the length of a butt connector.....
Do you have to remove the back door glass run and weatherstrip to access the clips?
