Old 04-19-2019, 06:36 PM #1
Greenmachine86 Greenmachine86 is offline
Greenmachine86 is on a distinguished road
Changed front pads
I changed my front pads today, when i got to the passenger side, i had trouble getting the pads to slide down in the right place. Finally got them to go. Noticed that the wheel would spin but not totally free. Drove around the block and noticed a hot brake smell. Seems like the brake is grabbing on that side. Any thoughts?
Greenmachine86 is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 07:30 PM #2
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears will become famous soon enough
sticky caliper piston is my first guess
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, TRD O gasket, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, LBJ, OTRE, Energy Suspension rack bushings, DRL delete, Big 3 wire, 3/4 rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 04-19-2019, 07:39 PM #3
So does that mean replace the caliper?
Old 04-19-2019, 07:47 PM #4
Kanoe Kanoe is offline
Kanoe will become famous soon enough
I'd suggest pulling that caliper off and see if you can get the piston to retract properly. Then clean and grease any pins and sliding surfaces which is normally part of a pad replacement job anyhow.
Caliper might be bad but it may just need a clean up.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
Kanoe is offline   Reply With QuoteReply With Quote
Old 04-19-2019, 08:17 PM #5
Brian. Brian. is offline
Brian. is on a distinguished road
Your first clue will be what the OLD pads were like. One worn more than the other (inside vs outside)? Then the pistons are stuck. That you had an issue fitting the new pads is also an indication. They can be rebuilt if you're a detail oriented DIYer, or replaced if you'd rather just buy replacements.
Brian. is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 01:27 AM #6
nissanh nissanh is offline
nissanh will become famous soon enough
Front calipers are fixed calipers so there are no sliding pins.
Did you have trouble removing the pads on the passenger side? Did you see any damaged dust boot? May be caliper pistons are seized or the aftermarket pad is thicker. Did you install the right number of shims?
Old 04-20-2019, 07:07 AM #7
The inner pad on the passenger side was tough to remove. I finally got it out, one of the pistons did not wanna re tract, but i finally got it to move. Im thinkn this is where my problem began
Old 04-20-2019, 07:20 AM #8
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough
MY GARAGE
MaineRunna's Avatar
MY GARAGE
Buy a new caliper. These four piston, fixed mounted calipers seize up all the time. I usually have to replace at least one caliper whenever I do a brake job on a Toyota truck.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, RCI skid plate, SPC UCA's & rear LCA's, Tundra brakes, BFG 255/85R16 Mud Terrain T/A's 224,000 miles
MaineRunna is offline   Reply With QuoteReply With Quote
Old 04-20-2019, 12:20 PM #9
of course you can replace one caliper, or replace both and be done and not worry about the other for a while. Some rebuilts come with pads, however usually junk pads
Old 04-21-2019, 02:58 PM #10
The caliper was the issue! Had one of four pistons stuck. After tryin to run down the prts, then they gave me the wrong one.... finally got the right one on! Works like a champ. Thanks for all the input from here
Old 04-21-2019, 07:19 PM #11
YOTAGUY93's Avatar
YOTAGUY93 YOTAGUY93 is offline
YOTAGUY93 is on a distinguished road
YOTAGUY93's Avatar
Sorry for thread jacking but i'm having an issue with my brakes as well. I just swapped out my old front brakes thinking they were the issue to my annoying squealing. Come to find the new ones are doing the same thing! I changed out my front pads with akebono pads and front rotors with brembo rotors. I also bed in the brakes multiple times. Can a bad caliper be my culprit? I can hear a faint whirring sound when i drive but idk if that's from my bad cvs or not. I adjusted my rear brakes and fixed a leaking rear axle seal. I bled the brakes multiple times as well. Any help is much appreciated...
00' Toyota 4runner Limited 4x4-Adventure/Camping Rig
17' Toyota Camry XSE- DD
98' Toyota Corolla- SOLD
87' Toyota Tercel- SOLD
YOTAGUY93 is offline   Reply With QuoteReply With Quote
brake , changed , front , pads , side
Anyone changed there own front Wheel Bearings on a 4th gen yet??? NCSCOTT 4th Gen T4Rs 118 12-11-2016 10:03 AM
Just changed front pads might need new calipers? jprhome Classic T4Rs 2 09-05-2015 12:02 AM
Changed brake pads and not the breaks grab GSMNP125 Classic T4Rs 2 04-23-2014 03:33 AM
Just changed front breaks and.... Gemini220 Maintenance/Detailing 9 05-17-2011 09:54 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
