Any aftermarket part will always be a crapshoot, regardless of what it is.
I've had both good and bad luck with cheapo eBay/Amazon specials, and both good and bad luck with the more expensive AutoZone parts.
OEM is the only guaranteed fix (minus lemons, or course).
For example:
- My $13 Amazon MAF is going strong after 2 years.
- My $35 IAC idled way too high. I ended up cleaning the living snot out of
my 200k original IAC and it works great now.
- Just a couple weeks ago, I tried my luck with a $50 eBay special brake
booster and it came out of the box bad (hard pedal). I used the $300
Advance Auto part and it works great.
- My Walker QuietFlow cat works great, and my no-name $88 muffler from
eBay works great too (just sounds very slightly throatier).
- I have 1 AutoZone fuel injector because I broke the head off one of mine like a dipshit. 3 years later and counting and working great. Everyone says STAY AWAY, but mine is fine.
- I've never had any issue with FelPro gaskets (and some people are replacing their valve cover gaskets every year due to failing FelPro gaskets)
Pretty much, if you have a spare vehicle and don't mind possibly wasting a little time, there's no reason to NOT try cheap parts. Just buy from a decent seller. If it works, great, and if not, return it for your money back. Just say it didn't work (which it truthfully didn't) and you'll get no hassle.
