04-24-2019, 12:34 PM
adding a 99 rear cargo 12v to my 97 questions
I was at the junkyard and grabbed a 99 rear cargo 12v outlet out of the 99. Has anybody added this to their 96-98? I was planning just to cut out the opening and pop it in and had questions about wiring it up. Is there any way to tap into the existing wiring near the back taillight so I don't need to run wire all the way to the engine area? Has anybody done anything similar that can help? There has got to be way to splice into something in the back to make it easier. Any help would be great. Thanks guys.
04-25-2019, 01:58 PM
There is no full-time 12V in the back that I can think of. If you are a running anything with a real draw, like a 12V fridge, you want a dedicated line straight from the battery with an in-line fuse anyway.
Best you could do is tap the power window line in the harness going to liftgate--solid blue wire on a '97.
My Backyard Frame Swap
04-25-2019, 02:19 PM
Did this when I was building out my rear sleeping platform. Wanted a 12V cigarette plug and USB.
I didn't use the stock 12v outlet but same idea. You can tap into the 12v positive from the rear roof light and ground anywhere. I've run air compressor on it but if you're looking for more juice then I would go with TheDurk's suggestion.
97 SR5 w/ elocker, 250K | BS 5100 adjustable front 5th gen coils, 5100 rear LC springs | KO2 285/70R17 on '15 Trail Rims | TBU | X-Bull 12K Winch | TG Sliders | front & rear NWTI bumper kit
04-25-2019, 03:10 PM
FWIW, the stock 12v outlet in the hatch area on later cars is not always hot. It's ignition switch controlled. That can be a pro or con depending on your needs.
Personally if I were running power back there for anything more than a cell phone charger, I'd run a dedicated wire from the battery with inline fuse. I personally wouldn't be comfortable running something like a compressor or fridge off light wiring, but it sounds like others have done so without issues.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
04-25-2019, 05:51 PM
Real Name: Jerod
Real Name: Jerod
I run a small 12V cooler off that with no issues. Toyota used quality copper wiring (not that copper coated junk) and I'm consistently surprised on how well it carries current. Same goes for speakers.
04-25-2019, 06:05 PM
Oh cool, that's great to hear!
1998 BMW M3/4/5
04-25-2019, 07:02 PM
Real Name: Jerod
Real Name: Jerod
I should have said this in the first post, but it's only a 5 amp cooler though. Not exactly big.
A portable air compressor though will draw between 15-20 amps though so I guess there's plenty of room (which I have also done). However drawing 15 amps from an air compressor for 5 minutes produces a whole lot less heat than running a 15 amp cooler in the back for a 10 hour road trip. That's where the dedicated line from the battery is nice to make sure you don't fry the wiring.
04-26-2019, 02:18 AM
Thanks for the help and recommendation. I actually recently installed some amps with a 3 way splitter from the battery. I'm going to use that for power with the inline fuse. What size in line fuse would be sufficient? The 12v fridge idea sounds tempting actually. I think id want to run a compressor off of it as well.
04-26-2019, 12:02 PM
Easily resolved. Use a hefty gauge wire. I like having the outlets live with key-out to power a fan for my dogs when parked.
Power Outlet Mod
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
04-26-2019, 12:04 PM
Fuse depends on wire size and length and that depends on the load. I believe the factory cig outlets are internally fused. The front ones are. 10A maybe? All the way in back you could do 14ga but I would prefer 12ga 'cuz I like copper and then fuse it at 15A. Could fuse 12ga at 20A but no point if the outlet will pop at 10A.
What are you going to run?
04-27-2019, 01:17 AM
Havent decided yet what I intend to run but just want to future proof so when I do run something. Fridge/cooler and compressor for sure, not sure what else.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
