Originally Posted by mendozer
I rented the compression tester the first go around. For the leakdown I bought the OTC kit, but then returned it since I was like hey I don't need this. The two seem so similar, cant I just use a leakdown tester for all of it? One tool would be great. Then of course there's radiator compression. Any good idea for a one master kit?
A compression tester tells you that you
have a compression leak. The leakdown tells you
where the leak is. That's the difference.
Oh, did anyone mention you need an air compressor to use a leak down tester?
A coolant system pressure test system is a whole other thing. Don't bother with that unless you have a leak. Auto parts stores also often have a kit for rental.
