Old 04-22-2019, 01:34 PM #1
Kyngfish Kyngfish is offline
Kyngfish is on a distinguished road
Wiring for raptor headlights
EDIT: should have said grill lights, not headlights - apologies.
Hi - I looked around for a thread specific to the third gen, I found one, but it was scant on details:
Grill/raptor LED light wiring w/pictures
I don't fully understand where the wires were actually actually attached to the power, but it made it sound like it would attach directly to the power coming in from the battery, so the lights would always be on if the car was on?
Has anyone else done this? Is there an advantage to having them always on if the car is on? SRQ recommends wiring them to the side lights, does anyone know of a thread that shows how to do this.
1998 Toyota 4Runner Limited 4x4 - Black
1986 Porsche Carrera 3.2 Coupe - Guard's Red
2015 GTI SE - Tornado Red
Kyngfish is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 01:09 PM #2
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The way he wired them in the thread you referenced is fine, because he tapped into the TAIL fuse. As you can see in the '98 EWD below, the 10A TAIL fuse is hot only when the TAIL relay has been switched on, and the TAIL relay is switched on only when the parking lights or headlights are turned on.
I would probably wire them differently, like SRQ says - i.e. instead of running a separate hot wire from the fuse box to the raptor lights, I'd probably tap one of the parking light wires (the ones shown in light green below) and run a wire to the raptor lights. The raptor lights are such low amp use that you would not be overtaxing the parking light circuit, IMO.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 04:59 PM #3
Thanks dude! So just basically cut the wire and solder the connection to the lights with an in line fuse, then heat shrink?
Old 04-23-2019, 07:01 PM #4
Real Name: Leon
Real Name: Leon
Yup, that'll work!
Old 04-23-2019, 11:01 PM #5
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
I’m generally a pedant about wiring. But for 3 little bullet LEDs, if the current is measured in milliamperes, I would just drop a power wire to one of the front parking lamps which is already fused.
DaMonkey is offline   Reply With QuoteReply With Quote
Old 04-23-2019, 11:10 PM #6
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
Yeah, I could see that. He could also cut all the wires and stop copying a Raptor because it's not a freaking Raptor and looks like poo on things that aren't Raptor's. Well, it looks like poo on them too but ya know....
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 09:27 AM #7
You know what they say about opinions...
Either way, the original grille has quite a bit going on, and going matte black with some pretty stark Toyota lettering and three little bullet lights is still overall a pretty simplified look compared to the OEM.
Personally I think that and some projector headlights go a long way to making the truck look fairly modern. But if you like, you can come to my house and rant about it. You're welcome.
Old 09-21-2021, 11:36 AM #8
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
sorry for the bump, but i'm a noob to wiring, never wired anything before in a vehicle. I don't really understand what was said in this thread. As a newbie to wiring, how do i go about wiring some raptor lights in? i have them installed in the grille, and i'm going to make them all run from one wire, but I don't know where to tap that wire in, or anything.
Help would be appreciated, thanks!
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
car , lights , power , thread , wiring
Bro got Raptor Thai Off Topic 47 04-04-2018 01:46 PM
Grill/raptor LED light wiring w/pictures Logan6 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-15-2017 11:19 PM
Switching from 03 to 06 headlights and had a question about the wiring momo.75 4th Gen T4Rs 56 04-03-2015 11:18 PM
wiring aux lights to shutoff with headlights SilverBullet01 3rd gen T4Rs 1 05-23-2009 04:33 PM
1988 4runner wiring (headlights) crimsonking32 Classic T4Rs 1 12-05-2007 12:27 PM
