Old 04-28-2019, 11:52 AM #1
Gymoutlaw Gymoutlaw is offline
Real Name: Will
Gymoutlaw is on a distinguished road
Real Name: Will
Question Help wire behind stereo beside antenna??
I am replacing single din head unit with double din. When I pulled aftermarket stereo out I noticed this black wire hanging down beside antenna? I assume it is a ground wire? Anyone know what it is and where it’s supposed to connect??
Thanks
Gymoutlaw is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 11:54 AM #2
Real Name: Will
Real Name: Will
Forgot to attach pic of wire
Help wire behind stereo beside antenna??-91dfe791-3993-49e8-acce-d17aaa1c1c21-jpg
Old 04-28-2019, 12:10 PM #3
Hepar's Avatar
Hepar Hepar is offline
Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough Hepar is a jewel in the rough
Hepar's Avatar
That cable is for your diversity antenna which is in the rear window. Not sure why they decided to cut it.
2001 4Runner 4WD Sport Package, Millennium silver, 110,000 miles, 2nd gen TRD Supercharger, Toytec BOSS coilovers, 890 OME rear springs, Bilstein 5125 rear shocks, custom Baldlands front bumper, PIAA 520 driving lights and fogs, 4x Innovation Sliders (welded on!), 18" Magnaflow muffler, JDM corners, 65" Thule bars, 20% tint, 16x8 FJ80 wheels on 265/75-16 Duratracs, Husky mats w/ cargo, rear diff breather mod, 3M clear bra, remote start, Pioneer AVIC-8200NEX
Hepar is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 12:33 PM #4
Real Name: Will
Real Name: Will
Any idea where to connect it back??
Thanks for reply!!
Old 04-28-2019, 12:41 PM #5
stuckinthemud stuckinthemud is offline
stuckinthemud will become famous soon enough
Unless you are going to install a stock head unit with a place to plug it in, there is no need for it. I just left mine dangling.
stuckinthemud is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 12:49 PM #6
MrBob MrBob is offline
MrBob is on a distinguished road
Thanks
I replaced a single din with a double din recently and just used the wiring Crutchfield provided. I also pulled the bent power antenna and installed a cheapo fixed unit. Everything works as it should.
I did see the diversity antenna jack under my dash but could see it hadn't been used in a long time, probably pulled when the PO went to an aftermarket stereo.
MrBob is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 04:03 PM #7
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Thanks for reply!!
It's supposed to have a smaller than standard size antenna jack on it. It only plugs into the Toyota radio, but you can buy a two into one adapter on Amazon. The end is cut off your's and you'd have to splice a new end on or replace the whole cable so I'd just leave it. I hooked mine up with the adapter and don't see a huge difference.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 06:44 PM #8
Real Name: Will
Real Name: Will
Thumbs up
Thanks to everyone who replied. I just put heat shrink over the end and left it. Radio seems to work fine without it.
antenna , din , ground , stereo , wire
XM antenna wire location TylerC General Discussions 6 05-07-2013 04:06 PM
broken xm antenna wire matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-25-2012 12:00 PM
Sirius antenna wire location? TylerC 5th gen T4Rs 3 04-19-2012 10:37 PM
XM antenna wire location TylerC New Members 0 12-28-2011 09:53 AM
Which wire is power at the antenna? Daveed Classic T4Rs 5 01-31-2007 10:24 PM
