Old 04-25-2019, 06:50 PM #1
pokeyman pokeyman is offline
pokeyman is on a distinguished road
Front differential noise
I ran the front differential with low oil and now it has a howling noise. I drain the fluid and maybe 2 cups of oil came out, and there where no damage parts that drain out. How long do you think the front different will last and should I change the differential or just keep on driving with the howling sound?
pokeyman is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 06:53 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
The howling sound you hear is the bearings gone bad. The rear diff bearings can take a real beating and still work but there's a point of failure for everything. It's only going to get louder as the bearings get more and more beat up.
326WHP 347TQ
Old 05-06-2019, 11:36 PM #3
Toyotayoda's Avatar
Toyotayoda Toyotayoda is offline
Toyotayoda is on a distinguished road
Toyotayoda's Avatar
in the front diff; if you have an A.D.D diff, the oil can only circulate if you are in 4WD, which is why Toyota recommends that you use 4WD once a month. If the oil can't get to the carrier bearings regularly, or the axle bearings, they will corrode and fail.
Toyotayoda is offline   Reply With QuoteReply With Quote
differential , drain , front , howling , oil
2016 SR5 Rear Differential Noise after 10K miles 4Rman 5th gen T4Rs 38 11-20-2020 03:48 PM
Rear Differential Noise / Rebuild? sovamind 4th Gen T4Rs 18 05-02-2019 06:37 AM
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
Differential noise. kolelt 3rd gen T4Rs 14 11-20-2018 10:35 AM
Rear differential noise compatibility trex1973 4th Gen T4Rs 1 02-16-2013 01:52 AM
