Old 04-27-2019, 11:39 AM #1
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
No power rear window or wipers
Just discovered this this morning:
My power rear window and wipers don't work.
The window works from the lock cylinder, but not the dash button. Wipers don't work at all. The wiper fluid works fine, and the rear defrost works (or at least the light comes on).
All the other dash buttons work fine.
This one's weird. Obviously the window has power, or the key would not work. The wiper isn't jammed up, and I don't believe the system 'thinks' it is, or the defrost wouldn't work (IIRC, the light will just turn back off right after you press it).
Thoughts where I should start?
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 04-27-2019, 01:09 PM #2
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Sent from my VS986 using Tapatalk
Much rear gate weirdness is due to broken or shorted wires in the harness between the gate and the body (up by the hinges). Start there.
Please give your year when asking for electrical help--ALWAYS. Rear wiring is very different between '99+ and before.
My Backyard Frame Swap
Old 04-27-2019, 03:26 PM #3
Real Name: Daniel
Real Name: Daniel
Thanks, I'll start there.
Yup I spaced there. Its a 99 Limited. I even thought that because of the 99+ dash change, but then completely neglected to mention it.
Old 04-27-2019, 09:31 PM #4
Gymoutlaw Gymoutlaw is offline
Real Name: Will
Gymoutlaw is on a distinguished road
Real Name: Will
I would check fuses and relays first
Gymoutlaw is offline   Reply With QuoteReply With Quote
Old 04-28-2019, 07:32 AM #5
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
As Durk suggested, check the harness.
See pics:
'02 T4R Rear Defrost
tvpierce is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 12:22 PM #6
Real Name: Daniel
Real Name: Daniel
I finally got around to checking this out yesterday.
I got a CEL p1520 (Stop Light Switch Signal Malfunction), so I figured it was time to see what was up. Research showed that this was often caused by shorted wires as well.
It did turn out to be 3 wires in the loom that were messed up. 2 were broken cleanly, and the insulation on the 3rd was worn away, so it was shorting. They were all broken right at the base of the rubber cover.
I replaced the 2 broken ones and wrapped the broken insulation one with electrical tape.
I had to split the rubber cover underneath the plastic bracket that holds it to the liftgate to get some slack on the wires, and that's where I spliced in. I wrapped the hell out of the split with black electrical tape and might apply some black RTV if I suspect water is getting in.
Now my window and wipers work, and the CEL is gone too.
Easy fix, I was able to do it during my lunch break at work.
Old 06-10-2019, 11:54 PM #7
geodiggr geodiggr is offline
geodiggr is on a distinguished road
Was anything else affected? My rear wiper, window, and remote door locks wont work...all went down at same time.
geodiggr is offline   Reply With QuoteReply With Quote
power , rear , window , wipers , work
Rear Window Power in Accessory Power WeAreSLO 3rd gen T4Rs 1 04-29-2015 03:29 PM
rear power window w6000 5th gen T4Rs 2 05-29-2011 08:39 AM
Windshield wipers and rear window blacklabman Problems & Warranty Issues 0 12-09-2010 07:55 PM
Rear power window/ Power locks Brian Keeler 3rd gen T4Rs 2 06-01-2010 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
