Old 05-25-2021, 07:58 PM #16
Outrider Outrider is offline
Outrider will become famous soon enough
Originally Posted by FD7683 View Post
I hope splicing the ground on mine will fix the issue because my truck was severely sputtering today and the gauge showed to be around 3/4th of gas and no orange light. I know it had zero gas on the tank - it's kinda a shame my VIN is included in the TSB.
Definitely worth the effort and very small cost. If it doesn't, then you only lost maybe a half hour and a few bucks. Mine seems to have fixed my problem, as my gauge has been acting perfectly normally for about 3 tanks now.
'99 SR5 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 08:00 PM #17
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
I've learned to use the trip odometer religiously every time I fill up the tank. At 230 miles I know to go find a gas station. By 280 I know I'm pushing my luck and might run out at any moment. Mine does the opposite and the needle falls pegged to E with the light on when I still have 6 gallons left, or 1/3 tank.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 05-25-2021, 08:25 PM #18
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
230 is when I fill her up too. Funny thing is the gauge has changed it's manners the last two months. It drops to E and light flashes when I fill it up and stays this way till I hit 40 miles then it kicks back up to full. Same behavior every time I fill up. I find this to be strange.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 08:54 PM #19
FD7683 FD7683 is offline
FD7683 will become famous soon enough
I spliced it today and added a new ground. Only time will tell if it fixed it :/
2000 4Runner Limited 4x4 Sport Edition V6
Old 07-01-2021, 11:21 PM #20
Update
Having gone well over a month and 5-6 fuel tanks, with a fuel gauge that acts perfectly normal, I can now say with confidence that the ground wire fix corrected my problem.
I am glad that I can now trust my gauge instead of my watching my odometer, to know when to re-fuel.
I am extremely glad that I did not drop my fuel tank and replace an expensive part that was actually working just fine. I would have been extremely pissed had I done that, and the problem persisted.
If your gauge flakes out on you even just occasionally, do yourself a favor and invest maybe $5 and a half hour of your time, and there is a good chance that your problem will go away. If it doesn't, then you didn't lose much at all.
Always try the easiest and simplest things first!
On a related note, I have learned that things are very often not what they seem. For years, I just knew that I had a defective fuel sending unit, and being a lazy tightwad, I just sucked it up and lived with the problem (while running out of gas several times).
Another time, based on symptoms, and my questions answered here, I just knew that I had a blown head gasket. I did one final test and determined that I didn't have one, and then found that I had a faulty fuel injector instead. Imagine how extremely pissed I would have been, had I paid $1,500 - $2,500 to have the head gaskets replaced (with the necessary related work), or replaced them myself, and the symptoms still persisted.
Old 07-02-2021, 01:42 AM #21
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
what were the symptoms of the bad injector, and how did you know it was the problem? Those are sometimes tricky to diagnose
Also, I think, even though the 4runner does not have a fuel gauge problem, I will do the ground splice on that fuel sending unit, just to be sure.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 03:52 AM #22
My splice job fixed the issue I had and my gauge has been working fine ever since.
Old 07-02-2021, 05:16 AM #23
heatmyzer9 heatmyzer9 is offline
heatmyzer9 is on a distinguished road
Originally Posted by Mudeprived View Post
I would love to get that kind of mileage. I have to fill up by 240 miles or it runs dry.
My gauge has been in full retard mode the past month or so, dropping to E and flashing when it feels like it. I had it in for inspection two years ago and the mechanic said it was the gauge when I asked about it. At that time it was just reading Full to Half. He offered to fix it but I declined and just followed the miles.
I have a 99, SR-5 and had the same thing happen twice. Startup, gauge on full, wait couple of seconds, gauge crashes to below empty, gas warning light starts to blink. Argggh.
I saw an old post that showed a burned out component on a board on their cluster that was blinking the gas light. The component is on the board behind the small white cover on the back of the cluster. Just unscrew the screws, take of the cover, unscrew the small circuit board and disconnect the ribbons and one small wiring connector on that small board. Behind the small board (on the main board) is an inductor labeled “L9”. Since it literally failed and smoked for the guy in the old post…..I decided to check continuity across that component. It had no continuity and had failed (no physical signs of failure though). One side of L9 leads directly to a pin on one of the cluster’s connectors. So I soldered in a 1 ohm resistor (didn’t have any inductors) bridging out the bad “L9” inductor. It worked fine after that.
I think that component pulls higher current when the resistance of the gas float drops/or the sender goes bad. I changed out a fuel pump and it even smoked the new resistors…did the repair again and no issues. For some reason when the gauge starts acting up, that component fails due to high current.
3rd gen gas gauge issue-6fced23a-9232-4a4a-8a5f-a123d72c9e63-jpeg
heatmyzer9 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 08:38 AM #24
disclaimer: I didn't mean to derail this thread, and only mentioned the injector to illustrate my point about things often not being what they seem.
The symptoms were a rough idle and a misfire code in one cylinder. There were also several other symptoms that led me to believe it was a leaking head gasket. (it was a very long and complicated train of thought) What nailed it down to being a faulty injector was when I swapped a coil pack between cylinders, and the misfire remained in that cylinder. Then I replaced that one injector with a $40 rebuilt one, and the problem disappeared. After that, I did the job correctly and replaced all of the injectors.
That was about 5 years ago, so the details I recall are fuzzy. I hope my explanation makes sense.
Old 07-05-2021, 03:40 PM #25
Danger Mouse's Avatar
Danger Mouse Danger Mouse is offline
Danger Mouse is on a distinguished road
when I got my 2000 the fuel gauge didn't work. found a reset procedure on here somewhere, maybe it was a different 4runner site, not sure. after the reset mine has worked without issue for the past year.
Danger Mouse is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:09 PM #26
diverscale's Avatar
diverscale's Avatar
Thanks for the details. Will remember that as I never (and hopefully never) encountered this problem.
1998 4runner SR5
Old 07-05-2021, 07:35 PM #27
LivingHI LivingHI is offline
LivingHI is on a distinguished road
My 99 would always drop to e shortly before start up. The fix for me was plugging in fog lights that was missing when I bought it. Been working good after that
LivingHI is offline   Reply With QuoteReply With Quote
driving , fuel , gauge , tank , truck
fuel gauge issue Ol'Blue 3rd gen T4Rs 10 11-25-2015 11:08 PM
fuel gauge issue NWFLBowhunter 3rd gen T4Rs 4 02-05-2015 11:26 AM
Gauge backlight issue LTDSC 4th Gen T4Rs 14 07-04-2013 01:41 PM
Gas Gauge Issue DirtDawg 3rd gen T4Rs 12 09-10-2011 12:15 AM
Temperature gauge issue leslie22 Problems & Warranty Issues 6 10-13-2010 11:27 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
