Old 09-29-2020, 01:05 PM #1
Aldo947 Aldo947 is offline
Aldo947 is on a distinguished road
1997 4Runner grinding/whirring noise - transfer case?
Hello Everyone,
I have a 1997 4Runner, 272,000 miles, 4WD, AT, 3.4L I purchased about a year ago.
I have an audible humming/whirring/roaring sound at 40-50mph I am trying to diagnose. Becomes more audible when you let off the gas and coast at these speeds, you can even feel a light vibration in the floor and steering wheel. somewhat noticeable at lower speeds, goes away above 60mph.
Ive been chasing this for about 3 months now while performing the below maintenance and hoping that solves the issue:
Is this a problem? - 1997 4RUNNER transfer case output front driveshaft. - YouTube
-Is the transfer case output to the front driveshaft supposed to have some gear/chain noise? Or is this a bad bearing? I thought this didn't rotate in 2 wheel drive? would it still make noise?
I also replaced the engine when I first got it due to failed cylinder #2. So I'm now getting the rest of it in order.
-Replaced the rear differential with known good used one.
-Replaced the rear wheel bearings and seals.
-Replaced the front wheel bearings, seals, and hubs.
-Replaced the front differential driver needle bearing with ECGS bushing.
-Separately replaced the front lower and upper control arm bushings.
-Changed rear/front differential fluid & transfer case fluids.
I considered road noise from newer cooper AT3's. But I'm still getting this coasting noise when the car is in the air, see videos.
3rd gen 4Runner rear noise2 - YouTube - Noise at rear differential.
3rd gen 4Runner rear noise3 - YouTube - Noise at rear drive shaft.
I'm hoping someone can help pinpoint the problem from the description and video. I don't think this noise is normal and I assume it will only get worse if I leave it.
Thanks.
Aldo947 is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 01:09 PM #2
I should mention I removed the rear driveshaft and drove in 4-wheel drive and still get the noise.
But i also removed the front driveshaft and drove in 2-wheel drive and still get the noise.
It my be a moot test if both differentials are rotating due to the wheels? But would this rule out the transfer case?
Old 07-13-2023, 07:51 PM #3
KorbinB KorbinB is offline
KorbinB is on a distinguished road
Hey experienced the same problem. I just replaced the rear diff with a rebuilt. Sounds still there when I drive at like 20-60 mph and let off the gas. I think it’s rotational based on the frequency. Did you ever figure it out?
KorbinB is offline   Reply With QuoteReply With Quote
differential , front , noise , replaced , wheel
1997-02 Toyota 4runner Auto Transmission and Transfer Case. Low miles. Shawnee For Sale: T4R Items 0 06-30-2020 04:42 AM
1997 SR5 4X4 engine replacement 99 Taco - transfer case harness different? Aldo947 3rd gen T4Rs 5 10-11-2019 10:45 AM
Transfer Case Grinding w/ Flashing 4LO and 4x4 Light 4boer2 5th gen T4Rs 11 03-20-2015 06:16 PM
Transfer Case Grinding - 2000 4Runner LTD 4RunnerCollegeKid 3rd gen T4Rs 8 02-09-2014 12:04 PM
WTS: 1997 Toyota 4runner Transfer Case OneMoreTime Classifieds - buy & sell (no commercial ads please) 0 04-10-2011 10:03 PM
