Originally Posted by Gymoutlaw
I am replacing single din head unit with double din. When I pulled aftermarket stereo out I noticed this black wire hanging down beside antenna? I assume it is a ground wire? Anyone know what it is and where it’s supposed to connect??
Thanks
I replaced a single din with a double din recently and just used the wiring Crutchfield provided. I also pulled the bent power antenna and installed a cheapo fixed unit. Everything works as it should.
I did see the diversity antenna jack under my dash but could see it hadn't been used in a long time, probably pulled when the PO went to an aftermarket stereo.
