Old 04-29-2019, 05:08 PM #1
pokeyman pokeyman is offline
pokeyman is on a distinguished road
vibration on the gas pedal
I am getting this vibration at the gas pedal every time i step on the gas pedal. The truck is not vibrating its just the gas pedal. What could cos this?
pokeyman is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 06:10 PM #2
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Start by checking if anything attached to the gas pedal is loose, the pedal bracket mounts, throttle cable, throttle body, etc. It could even be engine mounts.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 08:24 PM #3
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Interesting. Wouldn’t hurt to check the ujoints. And possibly rear LCA and UCA bushings make sure there isn’t play in the axle. As giving it gas could force the axle to move in unusual ways. Start at checking bushings, u joints.
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 05-02-2019, 02:52 PM #4
bohdanprok bohdanprok is offline
Real Name: Bohdan
bohdanprok is on a distinguished road
Real Name: Bohdan
Could be motor mounts, becasue the throttle cable is attached to the engine when you accelerate it gives that feedback into the pedal.
1998 4Runner SR5 - Stock as it gets for now
bohdanprok is offline   Reply With QuoteReply With Quote
Old 05-02-2019, 06:59 PM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's this... little rubber grommet thing breaks down over time. at least it fixed mine and also another member.
see this thread... he fixed his with a rubber stopper thing
Gas Pedal Vibration
Old 05-30-2019, 07:10 PM #6
XPdr1 XPdr1 is offline
XPdr1 is on a distinguished road
On a semi-related note, would anyone happen to know the thread and bolt size for the accelerator pedal? Mine was loose and of the only both in the bracket, the it was not tightened. I am pretty sure the PO did not use a bolt with the proper thread.
Looked in the forums and the FSM and could not find anything.
XPdr1 is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 12:03 PM #7
Why not just buy the OEM parts?
90119-06456 is the bolt that holds the pedal pivot to the firewall
91635-G0630 is the bolt that holds the cable to the firewall
(the second one may be superseded, but the replacement part would work fine too, obviously)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
gas , pedal , time , vibrating , vibration
Gas Pedal Vibration 4Runner4TW 3rd gen T4Rs 7 02-01-2019 09:54 PM
Vibration in gas pedal philo 5th gen T4Rs 4 07-23-2018 12:10 PM
Vibration in clutch pedal??? OldSven 3rd gen T4Rs 11 11-01-2016 06:38 PM
Vibration in brake pedal marlopez 5th gen T4Rs 20 05-22-2016 06:02 PM
Gas Pedal Vibration Martin8 4th Gen T4Rs 0 05-02-2006 12:45 AM
