Old 11-15-2011, 01:38 AM #1
jeeper1 jeeper1 is offline
jeeper1 is on a distinguished road
Squeaking when turning the steering wheel
Hey folks,
I tried the search function but nothing came up. Hopefully I can get some help
I currently started noticing a squeak; more like a squeal when I turn the wheel either left or right. I started hearing it when I park in reverse and have to turn the wheel to make it fit. Its from a certain point to a certain point and not all the time. I was wondering what you guys think it can be. There is no slop in the steering or any other symptoms. I was wondering if there is something I can grease down there as it sounds like it might just need some greasing. A pinpoint to where I can grease would be great. If not what could it be?
Thanks
- 99 SR5 4wd 3.4 - Camburg Coilovers and Upper Control Arms - OME rear coils - 33" BFG KM2's - 17" Raceline Wheels Black - Lockrite Locker in the rear - All-Pro Sliders - Cobra CB Radio - Sport Hood -
jeeper1 is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 02:34 AM #2
20034RunnerV84x2's Avatar
20034RunnerV84x2 20034RunnerV84x2 is offline
Real Name: Allen
20034RunnerV84x2 is an unknown quantity at this point
Real Name: Allen
here is a knuckle down below your feet, take some WD-40 and stay that. Make sure you have mats or some cardboard/ plastic to catch what drips off, after the drips stop take to for a ride with all the windows down, to get the smell out. Good luck, I'll post pics tomorrow. Same thing on my 03 Highlander before I traded it for my 03 4R V8, just got a little dry so that fixed the problem.
2003 Toyota 4Runner SR5 iForce 4.7L V8 2WD Natural White With Plastic Bumper Cladding, Everything Completely Stock.
Owned since 10/3/11
90,000 Miles and counting!
20034RunnerV84x2 is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 03:33 AM #3
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
is it coming from the steering wheel assembly or the steering pump?
i had a super annoying squeek (like a mouse on a wheel) coming from my steering wheel. it started up out of the blue and was pretty annoying.
i solved it by spraying silicone into the moving parts around the steering wheel / column. here is the catch though, it didn't go away for about 2 months. the best I can figure is that since the assembly is pretty tight, it is difficult to get the silicone to seep inside right away.
good luck & use silicone not WD-40 (more dust friendly)
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 09:22 AM #4
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
How loud is it? Does it changed if you give it some gas? I'm thinking it's your power steering belt.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 09:51 AM #5
BigRogers's Avatar
BigRogers BigRogers is offline
Real Name: Brian
BigRogers is on a distinguished road
BigRogers's Avatar
Real Name: Brian
I have had the same issue/noise coming from my steering column. I would love to see some pics of what you did......
2001 2wd SR5 | Daily Driver
2002 4wd SR5 | Build Thread | Lifted | Armored | Dual Lockers | Geared
BigRogers is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 05:02 PM #6
Thanks guys for the replies!
Its sounds like its coming from the steering assembly. Its coming from the outside and its pretty loud like a brake squeak/squeal when I turn the wheel at 3/4 to the left and 3/4 to the right. I will try to make a vid when I get home so you guys can hear it.
I dont think its the belt, but who knows.
Old 11-15-2011, 06:35 PM #7
Real Name: Allen
Real Name: Allen
I'll go get some pics now.
Owned since 10/3/11
Old 11-15-2011, 07:04 PM #8
Real Name: Allen
Real Name: Allen
That is what would need to be greased in a 4R.
And this.
Also look at the steering shaft that connects to the shaft inside, follow it to the power steering rack. Spray WD-40 or silicone spray, I would do Silicone spray because it doesn't attract dust. I know I said WD-40, but really anything to lube it will work.
Owned since 10/3/11
Old 11-15-2011, 07:27 PM #9
CT4R CT4R is offline
CT4R is an unknown quantity at this point
Guys i have this problem too?!!!!..when i turn the steering all the way to the left..and all the way to the right. Also noticed that the body "moves or leans" while turning the steering wheel. Is this a steering rack bushing issue?? or PS Belt? or some lube in the steering column?..
CT4R is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 08:42 PM #10
Real Name: Allen
Real Name: Allen
The truck moving when turning the wheel is normal. Look at my other post, if that doesn't fix it, look into other things.
Owned since 10/3/11
Old 11-16-2011, 12:22 AM #11
20034runner v8: i tried your other post..lubed under the steering, it did not work. I know for a fact that my rack & pinion is leaking and also possible that its bushing is also shut!!!.. i will try to relpace the R&P, is there a DIY for it?..
Old 11-16-2011, 03:36 AM #12
Thanks 20034runner for the pics! I havent had a chance to get the video yet, but will do just for reference to see if this what everyone else has. I was wondering what parts those are you are greasing so that I can find the exact location.
Thanks!
Old 12-15-2011, 02:06 PM #13
Triumphdog's Avatar
Triumphdog Triumphdog is offline
Triumphdog is on a distinguished road
Triumphdog's Avatar
I'm having the same issue. I noticed if I Pushed the tire left or right the sound spears to be coming from somewhere near the break dust shield. The squeal pretty loud and almost hollow sounding. It doesn't make the noise all the time, mostly when I'm driving slowly, or turning from a stop.
99 T4R 90,000 miles
custom front/rear bumper, custom sliders, custom roof rack, Camburg coilovers, Camburg UCAs, Bilistein 5100 series rear, Tundra coils with air bags, 255/85/16 MT KM2, K&N intake
Triumphdog is offline   Reply With QuoteReply With Quote
Old 02-07-2012, 09:25 PM #14
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Did anyone figure this out? Im having the same issue. On the driver side it makes a metal on metal sound, like a brake squeak when I turn. Its real annoying, its not the tie rod end, ball joint that I can tell. It sounds like its coming from around the brake, cv shaft. Did the OP or anyone have this issue before?
JayRolla is offline   Reply With QuoteReply With Quote
Old 01-07-2014, 01:45 AM #15
IrLoserBoy IrLoserBoy is offline
IrLoserBoy is on a distinguished road
@JayRolla that is exactly the problem I've got. Did you figure it out?
99 4runner limited 4wd
stock rebuilt mostly
ready for modifications!
IrLoserBoy is offline   Reply With QuoteReply With Quote
Replacing steering wheel with another Toyota/Lexus model steering wheel LexusFTW 3rd gen T4Rs 20 03-04-2021 12:24 AM
Steering wheel sticks when turning right, despite just getting aligned. wrestling160 3rd gen T4Rs 0 09-18-2011 06:24 PM
Squealing/squeaking when turning on full lock... wombie 4th Gen T4Rs 3 09-27-2009 11:03 AM
difficulty turning steering wheel miagi Problems & Warranty Issues 3 04-09-2008 07:07 PM
clicking when turning wheel? otterball21 4th Gen T4Rs 7 06-28-2005 02:14 PM
