Old 05-25-2019, 02:58 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by BostonJon View Post
Not yet. The problem seems intermittent but there is definitely fresh coolant in the valley (only on the driver side) whenever I drive the car and the level in the overflow reservoir slowly drops over time.
This may be totally crazy, but my theory is that the bypass pipe is leaking, filling up the chamber where the knock sensors are, and it’s seeping past the intake gasket and out into the valley. From there, it drips out the back of the valley and onto the ground. I’m just speculating because I don’t know how else fresh coolant is showing up in the driver side valley. If it were the hoses under the TB, the coolant would be in the passenger side valley, but that side is totally dry.
I’ve ordered the water bypass pipe, FIPG, knock sensor harness, and intake gaskets and plan to dive in and do it in the next few weeks.
It's almost certainly the intake manifold gaskets (some part diagrams might call it the lower intake manifold gasket). There's coolant passageways that go from the block through the intake manifold into the cylinder heads. These gaskets corrode and fail over time, it's very common. What's not common is the amount of coolant you are seeing.
326WHP 347TQ
Old 05-25-2019, 04:09 PM #17
BostonJon BostonJon is offline
BostonJon will become famous soon enough
Thanks for that info. The truck has 400k miles and I don’t see any evidence that anyone has gone deep enough into the intake to replace the (lower) intake manifold gaskets. I don’t have any white exhaust so I don’t think it’s a head gasket. The bypass pipe and lower gaskets are a pain to get to but it’s not a complicated project and the parts are cheap (even OEM) so I’ll get those swapped out and report back.
BostonJon is offline   Reply With QuoteReply With Quote
Old 05-25-2019, 05:55 PM #18
Going that deep into it replace every rubber hose on top of the engine. Including the two coolant lines to the IAC as well as the vacuum line that goes from the IAC to the two sides of the intake manifold for the idle air assist or what ever they call it.
I had weeping heater hose lines from weak spring clamps. I also had a small split in the coolant line going to the IAC. Both of these caused dripping behind the engine. Plus I’ve also had a failed manifold gasket filling up the valley.
Old 05-26-2019, 12:16 AM #19
Real Name: Jerod
Real Name: Jerod
Or you could be like me and bypass the IAC altogether... not recommended for climates that see freezing weather.
326WHP 347TQ
Old 06-01-2019, 06:32 PM #20
SilverRidgeRunner1's Avatar
SilverRidgeRunner1 SilverRidgeRunner1 is offline
Real Name: Justin
SilverRidgeRunner1 is on a distinguished road
Real Name: Justin
If you remove your Radiator cap did u notice your coolant leak return dripping from the rear and coming down the driver side on the bell housing
SilverRidgeRunner1 is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 07:01 PM #21
A little update....
Last night I finally tore into the project and got the intake manifold off. I found quite a bit of coolant in the area under the intake manifold. Interestingly, there was green coolant (previous owner) and red coolant (I flushed with distilled water and switched to Toyota red when I bought it) under there. I noticed that the intake manifold gasket - particularly the front and rear channels where coolant flows - were pretty badly corroded and no longer had any of the rubber around the mating surface. My theory is that this allowed coolant to seep out through the mating surface between the intake manifold and the head. Most of it likely burnt off when the car was hot but when the car was cool, it seeped into the valley and down the back of the head and onto the ground. I think this is why I was seeing more coolant on the ground after the car had been sitting for a while.
I don’t think the water bypass pipe was leaking but I replaced it while I was in there. Also swapped out the knock sensor harness. I did not have time to get everything back together so I don’t yet know if this will solve the problem, but from what I’ve seen in there I’m optimistic that I found the issue.
I’m going to clean my injectors and put on new o-rings later this week and get it all buttoned up and test it.
Stay tuned....
Old 06-01-2019, 07:36 PM #22
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Help - coolant in the valley - why?
Edit: Just saw your last post.
I’d imagine that those gaskets were the problem then.
Good luck with it!
Mantilgh is offline   Reply With QuoteReply With Quote
Old 06-01-2019, 08:19 PM #23
Good luck with it!
I checked out all the heater hoses because that would have been the easiest fix. They were all dry and there was no explanation for coolant in the driver side valley.
Old 06-02-2019, 12:03 AM #24
That happened to the 97 Limited Puppy hauler. Since I had the intake off I had the heads gone over. Valley full of coolant.
Getting a good bead of sealant on the bypass tube was a challenge. I don’t know why an o-ring wouldn’t have worked.
Old 06-03-2019, 11:43 AM #25
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
A little update....
Stay tuned....
I have the same thing happening, thought it was the bypass pipe but haven't dug into yet. Definitely interested in what you find, I've just been topping off the coolant reservoir every couple weeks for about the last 5.5 years now ha.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 11:55 AM #26
attached is a picture i took the other night, which i think makes it pretty obvious what was happening. at the bottom of the picture (front of the truck) - especially on the right (driver) side - you can see the pink coolant that was in the valley. you can also see that the rubber gasket material around the dual coolant passage ways was in pretty bad shape. most of it was still stuck to the head when i took the old metal gasket off. there was also some more minor leakage (seepage?) on the passenger side (left side of the picture) at the single coolant passageway. I think the rearmost passageway gasket was bad too and this is the leakage that I was seeing down the back of the motor and onto the bell housing. the coolant leak in the front was making its way down behind the timing belt and onto the water pump housing. i thought i also had a water pump leak but I'm hoping it was just coolant dripping down.
I never had the telltale white smoke of a head gasket failure so I think my leak was luckily limited to the valve cover gaskets.
i should note that this was a tedious and time consuming job, but not a particularly difficult one.
i may put some threadlocker on my valve cover bolts because I realized that they were extremely loose already after re-doing my valve covers less than a month ago. no wonder so many of us have VC leaks.
Help - coolant in the valley - why?-unnamed-jpg
Old 06-03-2019, 12:00 PM #27
i noted this above, but i'm fairly confident that my bypass pipe was fine. the FIPG material on the mating surface of the pipe and head was still pliable and I did not see any corrosion around the mating surface. how that I see how/where it is mounted, I don't think a bypass pipe leak would show up as coolant in the valley because the valley is situated higher than the bypass pipe. rather, a bypass pipe leak would fill the cavity under the intake manifold and drip down the back of the engine (the only way out).
in hindsight, it seems logical that the mating surface of the intake manifold gasket would be suspect - especially if it's never been replaced. in my naivety, i didnt know that coolant circulated through the intake manifold. had I known that, I might have suspected this gasket in the beginning.
Old 06-03-2019, 12:07 PM #28
RS Dude's Avatar
RS Dude RS Dude is offline
RS Dude is on a distinguished road
RS Dude's Avatar
I would buy some new Densos off ebay for about $25 a pair. Also, with a soft metal brush, clean off the mating surfaces of the intake manifold and cyl heads before you put on gaskets.
'96 T4R SR5 V6 Auto 2WD 329,000 miles
RS Dude is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 12:11 PM #29
that's what i bought. i plugged the valve holes with some painters tape and used a soft wire brush on a the end of a drill to carefully clean the mating surfaces. it cleaned up nicely and everything is back together. I just havent had time to get the plenums back on, refill with coolant, and test it. maybe this weekend i'll get to it.
i should also note that the recommendation in post #16 from gamefreakgc was spot on.
Old 06-07-2019, 12:47 AM #30
Real Name: Justin
Real Name: Justin
Well was this a successful resolution to your problem
car , coolant , engine , leak , valley
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 32 08-27-2021 10:13 AM
Dealer Coolant Flushed with Wrong Coolant? peebee 4th Gen T4Rs 35 07-02-2021 05:52 AM
Death Valley - Pleasant Canyon & Butte Valley - April 20-23, 2017 - PICTURE HEAVY boyfester So Cal 27 05-05-2017 05:26 PM
Death Valley - Saline Valley to Lippincott Pass Ape Runner Off-Roading 2 11-25-2015 03:20 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
