Old 05-05-2019, 05:32 PM #1
Myrunr2010's Avatar
Myrunr2010 Myrunr2010 is offline
Real Name: Dave
Myrunr2010 is on a distinguished road
Myrunr2010's Avatar
Real Name: Dave
Ignition single click - not starter
Iím not sure where to even start with trouble shooting. I drove my truck out this morning, it sat for ~2 hours, when I went to leave, got a single click from the ignition.
My initial thought was it must be the starter. So I pulled the starter, it tested sat at autozone, but I went ahead and got a new (reman.) starter while I was there. Put the starter in and still got just a single click.
With the New starter in, I decided maybe the battery was doing something wonky (even though itís new I.e. less than 3 months old). So I hooked it up to cables for a good while (15 minutes or so), and still got just a single click.
I was able to push start it to get it home, but pushing starting it every time I need to drive it isnít an option.
I think any sort of neutral safety switch can be ruled out. If I turn the key without the clutch in, it does nothing. With the clutch in I get a single click of the starter pushing out. Also if I press the ďclutch start cancelĒ button and turn the key I get a single click.
My starter is new as of today, battery is less than 3 months old, and alternator is ~1 year old. Also, when driving it home, I got no sort of indications anything was wrong with the alternator (a friend suggested it might be).
Thoughts? Ideas? Suggestions?
97 4runner SR5 3.4 manual
Tundra/LC Lift with Bilstein 5100's on 285/70/17 BFG KO2
2" "Fat Pats" body lift; 1.25" All Pro wheel spacers
Turbo Build; Rear Bumper Build; Front Bumper Build
Myrunr2010 is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 05:51 PM #2
sawguy sawguy is offline
sawguy is on a distinguished road
Start with battery terminals,,,clean cable ends and posts...tighten
Then check ground cable
sawguy is offline   Reply With QuoteReply With Quote
Old 05-05-2019, 06:11 PM #3
Myrunr2010's Avatar
Real Name: Dave
Myrunr2010's Avatar
Real Name: Dave
Yeah, Iím a clown, I just thought of that myself. I havenít done anything with the positive terminal lately (other than when the battery was replaced) but I had to put a new negative terminal on recently. Went and wiggled those around and it stared right up. Glad it was easy but man, I waisted a ton of time for something so silly.
Old 05-06-2019, 11:42 AM #4
Thumbs up
Glad that was it.
Old 05-06-2019, 02:01 PM #5
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
I would put your OEM starter back in and return the reman. Aftermarket starters/alternators for these trucks are almost all universally junk.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 05-06-2019, 02:36 PM #6
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is a jewel in the rough weekendclimber is a jewel in the rough weekendclimber is a jewel in the rough weekendclimber is a jewel in the rough
Real Name: Scott
I went through the exact same thing recently and it ended up the exact same way. Spent a week with the rig down and ended up with a new remanned Denso starter as well. Figured I rebuild the old one and then swap it back in and keep the remanned one as a spare (can do it in 30 minutes now). I've been contemplating doing a mega-thread of the steps for trouble-shooting this to hopefully save some others the headache.
weekendclimber is offline   Reply With QuoteReply With Quote
click , clutch , single , start , starter
Anyone know what the 4Runner's one click ignition is called? hanjohnbono 4th Gen T4Rs 8 10-16-2018 12:06 PM
V8 starter click, click VOOORRROOOOOOMMMM!! alia176 4th Gen T4Rs 3 08-14-2018 01:42 PM
A single click sound after shifting to drive and accelerating dhatcher 5th gen T4Rs 25 09-24-2017 08:56 PM
Starter click after replacing contacts sbsponger 3rd gen T4Rs 11 10-23-2015 10:15 PM
Starter Click, Click, Click. Jump starts immediately??? daugherty83 3rd gen T4Rs 17 09-18-2009 03:46 AM
