05-05-2019, 07:34 PM
Tires: Big is Badder right???
I finished my 1st set of Nitto Trail Grapplers MT 285-70r16... yes its a real unicorn...
I bought at 157k miles, and I'm almost 190k now (189.9) so safe to say, 32k miles on roughly a 40k estimate mile tire...
due to being one of a kind... I'm a cross-road... stay on the size or go to more 'main-stream' size...
Option A.. 265/75r16... essentially 31.6x10.5r16
Option B.. 285/70r16... essentially 32.0x11.5r16 (current - unicorn tire)
Option C.. 285/75r16... essentailly 32.8x11.5r16
I'm leaning bigger, essentially the 33' I know I can clear current, I have plenty of room, Pinch has met the BFH and it's not in the way, I've trimmed my limited flares, I still have stock front bumper...
benefit would be more clearance... I would air down to 7.5-10 PSI on the harsh AZ rocks... my tires are now missing sections, not just chunks, all the way to the outer inner layer.
I love to explore abandoned roads, lots of over-growth and remote places. the rocks are sharp and take a toll...
I do have RR dif lock, and it helps ALOT.
the last question is MT vs AT... I know it's preference... but I'm looking at experiences for the sharp AZ rocks (or SW USA). if any have lasted longer vs the other...
I know the Nitto Trail Grapplers, but curious about the 'hybrid' Ridge Grapplers...
I have searched... just decided to make new thread anyways...
BTW 10psi on 10ply MT's... is like 30psi on P-rated tires... hard as rocks... but they grip like a clingy baby monkey.
1999 3rd gen Ltd 4wd 3.4 auto dif lock - Build Thread SOLD!
2019 Tundra Sr5 CrewMax - 1 owner
Doubt kills more dreams than failure ever will.
05-05-2019, 10:01 PM
A warning about your Option C...
I have the same size tires and I was rubbing against my upper control arms with stock wheels and no spacers. You will need aftermarket wheels for the right route. Otherwise I have some Spidertrax 1.25" spacers I can sell you. IIRC the recommended level of lift to clear 33s is supposedly 4" but with enough cutting you can do it with 2" or 3".
American Racing makes wheels below $100 that are good quality if that's what you want to do. That's what I've got on mine.
'00 4Runner SR5 (242,100 miles)
3" Toytec/Bilstein lift, 285/75r16 BFG KO2s
'16 Ford Fiesta ST, pushing more boost than I should be
05-05-2019, 10:12 PM
I am running a set of spider trax
05-06-2019, 12:09 AM
285/75r16 will give you the most options. The Ridge Grappler is a hybrid at/ht tire, i would not get them for the level of offroading you are doing... I would recommend getting a tire with extremely beefed up sidewalls, 3 tires come to mind. bfg km3, cooper st maxx and stt pro... i personally am a big fan of cooper and have the stt pro, but i know guys that swear by the km3. st maxx is a hybrid at/mt, so better road manners.
05-06-2019, 12:21 AM
The ridge 285 only come in E 10ply...
The 265 come in both c and E (10 ply) rating...
I do understand it's new and possible design issue... But doubt it from such a company...
I am open to bfg ko2... Ran them, just always sold the vehicles that had them... with them before I wore them out...
05-06-2019, 02:05 PM
Real Name: Addison
Real Name: Addison
Not necessarily. You can clear 35" tires with 1" lift. Just depends on how much you are willing to "massage". I used to have 1.75-2" in the front and cleared 285/75R16's with ease after some minor pinch weld work and the right offset on the wheels. Don't forget that getting an alignment with the correct amount of castor plays a HUGE roll in tire clearance as well. More castor moves the tires away from the firewall, greatly improving clearance. Lots of the reason people go with aftermarket UCA's - you get even MORE castor - but you can still maximize it with the factory UCA's.
Have you ran the Ridge Grappler? Toyo makes Nitto tires and the Ridge Grappler is Nitto's version of the Toyo RT. The Toyo RT is made with the same insanely strong tire carcass as the Toyo MT. I ran the RT for 2 years on my last truck and loved them. Lots of highway and offroad miles. I have 315/70R17 Ridge Grapplers in my garage, waiting to go on my 3rd gen.
K02's are a great all around tire but I would not consider them to be as tough in the sidewall as the Nitto's or other comparables. The Cooper STT Pro's might be a good option for you as well, as they are a VERY tough tire. I ran them for about a year on my last build and I know a ton of guys here are running them and love them.
05-06-2019, 02:37 PM
Real Name: Tyler
Real Name: Tyler
This. I ran 285/75s with just hammering the pinch weld down on 3" lift. Now I run 37s with less than 2" lift with a 1" BL. Just depends on how much you want to hit or cut.
Also if bigger is badder I have to vote for 37s...
Oh, and I guess to give actual input on this. Vote +1 for ridge grapplers. Never used them on the 4Runner but have multiple friends with nothing but good things to say both new and after a year or so.
2000 4Runner:Kings, 37s, lockers 2018 TRD OR:stock and staying that way
05-06-2019, 03:27 PM
The Ridge Grappler was the best tire I've ever run. I'm currently on PitBull Rocker Radials in 35x12.5x17. Prior to those I was on 295/70/17 Ridge Grapplers.
The Ridge Grapplers are fairly quiet on the highway, the balance with very little weight, and they hook up off-road almost as good as the PitBulls. The sidewalls are super tough. A lot of my local wheeling is on shale and welded tuff. I've given them more opportunities to slash a sidewall then most and they have never cut. Last year I ran the Dusy with them and had zero complaints. I buddy that wheeled it with me was so impressed he ditched his MT's in favor of the Ridge Grapplers. Once I kill these PBR's 37" Ridge Grapplers are going under my rig.
As far as tire size itself goes, bigger is better in the rocks and worse on the highway. If your goal is to be more capable off-road go big. If it's to have a DD that can take you off-road when needed stay smaller.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
05-06-2019, 08:13 PM
If you want an off road tire that'll last longer try the ST Maxx, you can get them in a skinny 33 also so less fitment issues. I've got 50k on mine and they've got probably right at half the tread depth left. It's amazing how well they wear, and how well they handle in almost any situation.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
05-06-2019, 10:59 PM
Real Name: Sean
Real Name: Sean
Any advice on how to clear 33's? I have a 2.5in lift, will they rub?
05-07-2019, 11:07 AM
Real Name: Blair
Real Name: Blair
Check out the Pro Comp Xtreme MT2 in 285/75/16. I’ve got 5 days on them of heavy off-roading/crawling and can’t say enough good things about them. Our terrain here has similarities to yours. Coming from the Cooper STT Pro I cant believe how good these work in sand and rocky hard pack desert. They are also “D” rated and under 50lbs per tire. Almost 15lbs less per tire than the STT and really noticeable with our motors. The only negative I have is they’re fairly noisy at highway speed. 4Wheel Parts usually has them at $250 off for a set.
2001 SR5 - ProComp 69 series wheels, 285/75/16 Pro Comp Xtreme MT2 Tires, King extended travel front coilovers, 890 rear coils, King remote reservoir with CD adjuster in rear, Total Chaos UCAs, 4x Innovation sliders, Gobi Stealth rack, Savage rear bumper and skids, ARB onboard air, ARB rear locker, EIMKieth PCK, Pioneer head unit
05-07-2019, 11:22 AM
Real Name: Tony (no surprise)
If you are willing to get SPC UCAs, on the "G" setting, several here have stated that 33s can fit with no pounding. This is what I'm doing now...
2000 Limited, E-locker
Maintenance/Build Thread
05-07-2019, 11:32 AM
Real Name: Sean
Real Name: Sean
Thanks, I hope they aren't too expensive lol
05-07-2019, 11:36 AM
Got them in a group buy (check that section) for $400 delivered. Part number 25460.
05-07-2019, 11:45 AM
That's where I'm at and no problems. Using ~4.5" BS wheels with the STT Pro 285/75-16. Actually thinking I may back off the SPCs to "F".
Only rubbing I have is at the back on the stock mud flaps at full flex.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
