Originally Posted by heat
That's the first thing I'd check, based on the symptoms.
Originally Posted by 19963.4lsr5
I must add that bad brake lines (rubber hose) will also do what you are describing. The inner lining delaminates and can ball up and block the line which will not let the caliper piston float.
But if both your front brakes are acting the same then I’d look at the master cylinder
Sorry forgot to follow up.
Before replacing booster or MC, i had already pulled the calipers off a parts car because before this brake issue i noticed 1 of the caliper's pistons had seized.
I had also replaced the soft lines on both sides.
I ended up swapping the MC from my parts car and that did the trick. Ive put about 300 miles on it since then and everythings been working great.
Thanks
