Old 05-10-2019, 10:15 PM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Talking Slipping and Stuttering Transmission Turned Into Complete Success.
I have been waiting for quite some time to have some valuable information to add to this forum. Well tonight I got my opportunity!! Complete success story.
My transmission has taken about 6 seconds to shift into reverse ever since i purchased my truck a year ago. Before this winter I drained the pan and added the correct amount of Max Life Valvoline ATF to fill her up. Truck ran great even across the state of Michigan for a couple road trips. I always noticed a little studder around 70mph with cruise control engaged going up hills and such but never anything more.
Fast forward through a Michigan winter, and yes this 250k mile truck has been my daily driver ever since I paid only $2,200 for it last year. In the cold temps my truck wouldnt engage into reverse or drive untill it idled for at least a half hour. It also started to slip and stutter very significantly under load in first gear and then eventually in all gears under minimal throttle.
Now that we have received some warmer temps in the state I've decided to check the fluid as I was scared to even do so before. To confirm my worst fears it smelled burnt and it was pitch black. F*** I thought to myself. Here we go.
It wasnt a huge issue because I have a low mileage unit waiting to be swapped in that I had only purchased for $300 locally off of the book. So I did some research. A couple posts on here and a Lexus forum regarding the A340 family transmissions and boom. I thought it was worth a shot to drain the pan, drop the pan and at least inspect the filter as I have an OEM filter I had purchased for my new unit laying around in the basement.
I drain the fluid and it looked like the attached picture of black fluid in a bucket. I also noticed that there was a rubber gasket which wasnt OEM obviously because it wasnt Toyota FIPG.
So what do I do? I proceed anyways.
The magnets were filled with goop more so than the other unit I purchased and more so than any other documented magnets I had ever seen on this forum or any YouTube footage.
I cleaned the pan and the magnets, installed the new filter and reinstalled the pan, this time with JB Weld high temp RTV as I didnt want to risk using the good stuff (the Toyota fipg I have) if it didnt work out.
After sealing up the pan I added a gallon of Valvoline Max Life ATF and some Lucas Oil Additive which was also advised against on this and other forums by some.
Guess what folks? I'm coming to you LIVE from the couch in my basement. Sitting in a fresh, clean pair of boxers that my girlfriend washed for me with a cold six pack of Heineken on my coffee table proudly announcing that my truck runs better than it ever has. And I ran the hell out of it on a 30 minute test drive.
My game plan now is to purchase another OEM trans filter to install in about 12k miles and a couple inline trans filters, one to be installed every 3k miles from here on out. Every oil change I will drain the pan and add a gallon and a quart of fresh Max Life ATF fluid untill the fluid stops being dark and returns to a red color. At 12k I will introduce another bottle of Lucas into the system as well. And hey, here's to another 250k with the original trans?
I hope so! And I hope this can help anyone in the same predicament I was in. You know why I love toyotas? One word.
Resilience.
Slipping and Stuttering Transmission Turned Into Complete Success.-screenshot_20190510-215917_gallery-jpg  Slipping and Stuttering Transmission Turned Into Complete Success.-screenshot_20190510-220531_gallery-jpg
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 10:19 PM #2
Real Name: Werner
Real Name: Werner
P.S. I quite literally called a mechanic buddy of mine during this process to ask if trans fluid and oil could mix. (Out of my own stupidity.) And those magnets have a pit in the center of them because I had already pressed on them with my finger. Before I had done so it was just a mound of crap. But no large shards. Cheers!
Old 05-10-2019, 10:31 PM #3
pokeyman pokeyman is offline
pokeyman is on a distinguished road
The ony way to get the fluid red again is do a flush
pokeyman is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 10:36 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
We’ll have to get you some better beer to celebrate with my man. In all seriousness, congrats on your new lease on that transmission
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 11:06 PM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Glad to hear you revived it!
You are right, most people on here are against additives. But when you are faced with an imminent failure or no other option, they can sometimes save the day. I've had good experiences with several additives that many were against.
326WHP 347TQ
Old 05-10-2019, 11:13 PM #6
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Did u figure out why it overheated? It could happen again
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-10-2019, 11:50 PM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, I think it might be a little premature to celebrate. Since that fluid was black, you most likely have significant sludge deposits inside your trans. I'm guessing you exchanged around 1/2 your fluid capacity, 6 quarts, because that's approximately what I got out when I dropped my pan and replaced the filter. As that new fluid with fresh detergents starts working on all that built up gunk, it might free some of it up and become lodged in fluid passageways and then you'll have issues again. You were pretty much in a position where you had nothing to lose since you were already having issues with it but I wouldn't start celebrating until you get a lot more than 30 miles of driving post servicing. You showed significant debris on the magnets. This means your internal components have worn excessively. My magnets had maybe 5% of what yours showed. i hope I'm wrong but I think your trans is on borrowed time.
Old 05-11-2019, 06:36 AM #8
Real Name: Werner
Real Name: Werner
I live in beer city USA so it is sad that's what I had last night hahaha
Old 05-11-2019, 06:37 AM #9
Real Name: Werner
Real Name: Werner
It never overheated it was just a starved pump by an entirely clogged filter, at least never overheated while I owned it!
Old 05-11-2019, 06:41 AM #10
Real Name: Werner
Real Name: Werner
The other transmission that I have almost showed zero debris and completely red fluid when I dropped the pan. So this is significantly worse. I do agree with you! Letting lose a lot of gunk is what happened when I initially put a gallon in last fall and over this winter it got to work which is why I had these issues. I did a cold start this morning and didnt let it warm up. Shifted right away into reverse and extremely responsive, also no stuttering yet or slipping. Will add the inline filter and keep you all up to date on the progress. At this point it's worth doing this just as a testament to the quality of the product. Let's see if we can prove all the anti flushers in the 3rd gen community wrong with this specimen. Thanks Tim!
Old 05-11-2019, 06:45 AM #11
Real Name: Werner
Real Name: Werner
Depending on the long term results I'm going to swear by the stuff!
Old 05-11-2019, 12:05 PM #12
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, definitely update us as time goes on. If you end up getting a lot more miles out of this transmission after it was abused so bad, that would be awesome.
Old 05-11-2019, 02:17 PM #13
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
You should do the flush and change all the fluid;
YouTube
Wedgy is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 02:55 PM #14
Real Name: Werner
Real Name: Werner
YouTube
I'm planning on doing that once my inline trans filters come in, anyone have any links? The only ones I've heard of are Magnafine through Tim and others.
Old 05-12-2019, 11:44 AM #15
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I have seen other brands, sometimes listed as power steering filters.
I have been using magnafine for years and don't plan to switch unless someone comes out with a better one....not a cheaper one....unless better and cheaper.
the last one I got was smooth stainless steel instead of the ribbed black body
flushed my tranny and new magnafine yesterday, after 4 years of mountain roads and gravel roads, and about 50k, looked good as new ( however about 15k ago I did do a drain and fill , 4qts instead of 12)
been running amsoil….no debates please on types of oil to use
filter , fluid , pan , purchased , truck
Transmission Slipping jeff_connors 3rd gen T4Rs 15 12-29-2014 12:08 AM
Success! Lift Complete w/one question danthemanx07 3rd gen T4Rs 10 02-03-2013 06:26 PM
Transmission slipping Soxnation13 Problems & Warranty Issues 1 09-03-2012 12:28 AM
Transmission slipping :( tofu 3rd gen T4Rs 19 01-08-2012 12:17 AM
when is transmission slipping not really slipping craigatkins Problems & Warranty Issues 2 07-30-2007 01:40 PM
