Old 05-22-2019, 02:50 PM #46
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Originally Posted by Rancho5 View Post
Hope no one considers this a hi-jack...Maybe some suggestions for 01-02 owners to minimize this failure?
As an 02 owner, I’m currently using Dino fluid and have been wanting to switch to synth, just haven’t yet because it runs so smoothly...at 160k. PS: External cooler installed.
Redline D4 or Amsoil ATF. Is the cooler installed as bypass or in series? Depending on your climate bypassing can make the trans take longer to warm up.
Old 05-22-2019, 03:03 PM #47
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
@Rancho5 if you want a cheaper alternative than redline or amsoil I'd suggest Valvline Maxlife. A lot of guys use it and it works for me. Also use that oil ever since I've owned the truck and my oil is very yellow still at 3k vs when I first got the truck it was very black. Just throwing that out there.
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 04:01 PM #48
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Looks like he's in New Mexico, so bypassing altogether should be fine. Most cooler manufacturers will include a note about those living in climates that see temps below freezing on a regular basis to not bypass the stock cooler, so I think he's good. I also have it bypassed but we only see below freezing at night, about 10 nights a year so it heats up pretty quick.
326WHP 347TQ
Old 05-22-2019, 04:25 PM #49
T4R2014's Avatar
T4R2014's Avatar
That's the engine oil. The ATF was good but they reformulated it to meet Toyota WS. As a result it is thinner. I had hard shifts using it after. Not my first recommendation anymore. Combining it with a bottle of Lucas stop slip would help thicken it for an already dying transmission, but should only be used for that purpose anyway.
I'd recommend spending more up front for the best ATF. Had many transmission builders and re-builders agree with this as well.
Old 05-22-2019, 04:34 PM #50
Rancho5 Rancho5 is offline
Rancho5 is on a distinguished road
Since I’ve got Redline everywhere else, D4 it is. Any idea how much it takes? I’ve got the tranny cooler everyone recommends. Can’t think of the name here at work.
02 Thundercloud Sport, 155k.
Rancho5 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 04:38 PM #51
T4R2014's Avatar
T4R2014's Avatar
Generally it is a gallon when you drain it. Last time I got 4.5 quart though. Still haven't added that half quart...
Old 01-21-2020, 09:54 PM #52
Real Name: Werner
Real Name: Werner
UPDATE: Shes still running. I did need to replace the trans filter again, trans pump was starved on cold starts with colder temps leading into the winter, magnets had more debris on them however no large metal shavings still. Still running Valvoline maxlife, upgraded to 33 inch tires with stock 4.10 gearing, submitting my trans to more abuse than ever and I have no issues to report. Except that this spring im doing a manual swap HAHA
Old 01-21-2020, 10:16 PM #53
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
oh wow I didnt know that! I was really thinking about scoring the newest 3rd gen I could find as well haha
Here's an 01 that hasn't exploded, yet....321k all original miles so far....yet it is time for the next trans flush.....the last 2 yrs have all the cool features the first 4 didn't....
Old 02-19-2020, 06:57 PM #54
Real Name: Werner
Real Name: Werner
Honestly theyre "lifetime filters" but I wouldnt hesitate to just go ahead and change out the trans filter ever 40k miles and keep your fluid good and youll be fine. Its easy to prevent tragedies, hard to remedy them. I am still using this trans though. Ran it harder than ever this past summer at the dunes.
Old 02-19-2020, 06:59 PM #55
T4R2014's Avatar
T4R2014's Avatar
Shows how tough the A340 is.
filter , fluid , pan , purchased , truck
Transmission Slipping jeff_connors 3rd gen T4Rs 15 12-29-2014 12:08 AM
Success! Lift Complete w/one question danthemanx07 3rd gen T4Rs 10 02-03-2013 06:26 PM
Transmission slipping Soxnation13 Problems & Warranty Issues 1 09-03-2012 12:28 AM
Transmission slipping :( tofu 3rd gen T4Rs 19 01-08-2012 12:17 AM
when is transmission slipping not really slipping craigatkins Problems & Warranty Issues 2 07-30-2007 01:40 PM
