Old 05-11-2019, 02:05 PM #1
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Train horns... anybody run them?
Heard a set today and figured it was some big ass F950(joking) P/U. It turns out it was a 3G runner... I was wondering if anyone here has them and where did you find the room?
I used to think that train horns were silly on anything other than a TRAIN.
but i kind of like the idea...
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 03:20 PM #2
metallitera metallitera is offline
Real Name: Red
metallitera will become famous soon enough
Real Name: Red
I've seen guys mount them under the truck where their spare would normally go. Air is usually the issue with them. Multiple trumpets take a lot of air. I've seen guys mount pancake compressors in their toolbox and power them with large inverters, even plumbing an additional air tank into the mix. This was all when I had my diesel dually.
I ended up going with a smaller setup off of the shelf at oreillys, it had 2 trumpets and a small air pump and wiring harness. Easy install and was still loud as hell. Mounted mine behind the grill of my '96 F350.
You should have enough room for a smaller setup like that behind our grill. I've also seen guys mount them in the front fender.
If you have on board air, you will have more options, but if you don't, I'd go with a setup that has a small pump just for the horns.
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
metallitera is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 07:08 PM #3
Novashards Novashards is offline
Novashards will become famous soon enough
Try these! Audio clips in link.
Are YOU Tired of Your WIMPY Stock Horn? Put in 4 Cadillac Horns!
Novashards is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 08:44 PM #4
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Had them on my 3rd gen and both of my 4th gens. Love them
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 09:12 PM #5
absalom's Avatar
absalom absalom is offline
Real Name: Jordan
absalom has a spectacular aura about absalom has a spectacular aura about
absalom's Avatar
Real Name: Jordan
Had the 4 Cadi horns. I personally don’t believe they live up to the hype. They also block a ton of airflow to the rad if mounted in factory location.
Switched to red Hella horns, the sound is much less pleasant but far far more effective at getting other drivers’ attention. They also seemed to allow other drivers to localize the sound better than the Cadillac horns which just seem to be omnipresent.
OP, what’s your goal? Safety or just outright being obnoxious; no judgement either way.
Also, the train horn builds (when done right) are $$$. A lot of money for a novelty, which does less (in my opinion) to get the attention of a distracted driver and instantly distracts every other driver in a 1 mile radius - which is fine if you’re just looking for outright attention.
In the end, I believe the money would be better spent on useful mods and maintenance, and becoming a more defensive driver so you won’t need to rely on your horn as often.
absalom is offline   Reply With QuoteReply With Quote
Old 05-11-2019, 09:54 PM #6
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
The only reasons I can think of to make a road vehicle sound like a train is either for shock value, or to compensate for feelings of inadequacy. There may be other, legitimate reasons. I'm just not aware of them at the moment.
In the opinion of me and others, waste of money.
thennen is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 06:19 AM #7
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
I don't remember the last time I used my horn.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 01:08 PM #8
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
Train horns...  anybody run them? Hahaha same
I had a train horn on my old gti but it was on airride so i already had a lot of the setup. I used it to scare friends, thats about it, used it less than a handful of times toward other drivers.
It leaked air like crazy so i disconnected it and am just now realizing that its probably still under the bumper of that car.
Like stated above, its a novelty that loses entertainment factor pretty quickly.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 02:07 PM #9
giguchan's Avatar
giguchan's Avatar
Thanks Guys...
I have a buddy who has them installed in his Tahoe... I guess maybe there is a lot more room in there compared to a 3G engine bay.
Thanks for the all of the replies.... seems like a lot of money for occasional use. I heard some more today too... I've see that the Jeep people love them too. but mostly on gigantic Fords and Chevys.
Thanks again.
Currently 194K
Cheers
Old 05-12-2019, 02:08 PM #10
giguchan's Avatar
giguchan's Avatar
Where did you mount the trumpets? and the compressor?
Currently 194K
Cheers
Old 05-12-2019, 02:28 PM #11
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I got some cheap harbor freight horns that were near as loud as Hella...or so they said....they are louder than stock and sound better....cost like 15 for the pair in a kit with relay and wiring
did not use the relay, my son told me they would be louder if I used the relay and wired to my battery, would still be triggered by the stock horn circuit.... don't really know if true
Old 05-12-2019, 03:02 PM #12
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
The air horns or these? 2 Piece 12 Volt Electric Horn Set
I have a pair of those chrome ones, they're at least 8 years old now and still working great, the included relay sucks though.
OP lives in Long Island, believe me, he needs horns.
Old 05-12-2019, 05:33 PM #13
det107 det107 is offline
det107 is on a distinguished road
But do you remember the giving them the finger?
det107 is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 05:59 PM #14
Real Name: 3 Bears
Real Name: 3 Bears
so many times
Old 05-12-2019, 08:45 PM #15
04rnr's Avatar
04rnr's Avatar
I cant remember exactly on the 3rd gen, but the compressor was in the engine bay somewhere and the trumpets were in front of the radiator. sorry I wished I could be more help, I looked for some pix but cant find them
2007 Sport.
find , horns , room , silly , train
Chasing The Train Khjphoto Off Topic 0 07-07-2016 02:32 PM
MOD: got train horns in your t4r? hornblasters install, look inside gshadow325 4th Gen T4Rs 44 02-01-2016 01:12 PM
Train Horns Jerrydog 4th Gen T4Rs 20 05-18-2011 11:34 AM
