Old 05-12-2019, 09:05 AM #1
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
SOLVED!!! Water in driver's side floorboard
So, I have read over time where many have posted about water being in the driver's side floor area. There have been a number of possible causes like plugged sunroof drains, plugged drain holes etc.
I found a solution to my "water issue" and it may help. Underneath the carpet on the driver's side floorpan, there is a round, rubber plug about two inches in diameter. Just looking at it, it looks fine. I decided to swap it out with one I pulled from a parts yard and covered it with gorilla tape. Low and behold, the water-in-the-floorpan DISAPPEARED. Carpet is dry as a bone even in this torrential rain we are having. Hope this helps someone out.
Seems like this plug shrinks over time and water gets in. Rather than replacing it, it might work to take it out, clean it and put some silicone caulk around it and then cover it in heavy-duty tape just to make sure it stays put.
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 09:45 AM #2
Raymondfj40 Raymondfj40 is offline
Raymondfj40 is on a distinguished road
Wet carpet...
Had the same issue... rubber plug was brittle and hard... replaced and 👍🏼👍🏼👍🏼👌🏻
Raymondfj40 is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 12:25 AM #3
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Mine is coming from seal around door. Fir some reason there is a gap at the bottom that sends all the runoff inside but only when parked downhill. Uphill doesn't.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 07:36 AM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I dipped all of mine in some LM Ceratec some years back, and they have kept as new since......
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 09:34 AM #5
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
Aha!
So not 4Runner related, but just yesterday, my wife and I spent over an hour yesterday trying to discover a leak somewhere on her '03 Rav4's driver side floor. A BUNCH of water got in last week with all the rain, so after shop-vaccing it dry, we did the test with the water hose, etc, but couldn't recreate it.
All seals under the dash, door seals, etc, were bone dry,
I'll pull the carpet to see if it has a plug as well. I'm assuming it would.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 10:00 AM #6
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Mine was from aftermarket wiring from the previous owner. The wired around the fire wall grommet and popped it out of place instead of poking a hole in it and placing silicone around the wire once ran through the hole. I fixed this issue myself.
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 05:18 PM #7
boiserunner boiserunner is offline
boiserunner is on a distinguished road
Anyone have any other ideas on this? My '05 is having the same issue, isn't the plugs as they are bone dry and water was flowing over the top of them. Poured water down the front of the car and it is draining down to a piece of the frame that seems to be leading to the vehicle. The picture is of where I think its dripped but I can't figure out where that leads. Imgur: The magic of the Internet
boiserunner is offline   Reply With QuoteReply With Quote
drivers , plug , plugged , side , water
Leaking water onto floorboard - A/C issue? jediwebdude 4th Gen T4Rs 2 09-10-2016 01:41 AM
Hot driver and passenger floorboard Hobson 4th Gen T4Rs 1 08-21-2015 12:30 AM
Clunk from under driver side floorboard Panzerpatty 5th gen T4Rs 6 08-18-2015 07:00 PM
Driver Side taking on water Deputy 3rd gen T4Rs 9 07-08-2014 07:47 PM
Suggestions on stopping Driver Side Rear Quarter Window from Leaking Water docmartinez24 3rd gen T4Rs 2 06-09-2011 02:03 PM
