Old 05-12-2019, 05:44 PM #1
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
Dumping coolant and trans oil
I noticed a small oil leak a week ago and then a few days ago I started smelling coolant, could not find where it was coming from, the radiator was still full at that point
This morning, when I started it up, it spewed transmission fluid all over the ground, appears and smells like transmission fluid. Also the coolant disappeared, radiator is empty and it appears to have sprayed somewhere above the coil packs - the top of the intake hose and coils are all wet. The transmission fluid appears to be leaking from above the transmission near the dipstick
Seems like there's a line somewhere that broke, anyone deal with this before?
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 06:20 PM #2
PS doesn't seem to be the head gasket.
The engine oil is clean- no water
Old 05-12-2019, 06:51 PM #3
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
if the radiator is empty and the transmission is blowing off excess pressure out the breather or dipstick?
is it the original radiator?
I would
drain the radiator and see what is all in there?
drain the transmission and see what is in there?
visually check the trans cooler lines (I'm assuming you have an auto if you have a trans dip stick)
visually check the oil cooler coolant lines on the drivers side as well. they could be leaking but why ATF seems involved points to pink milkshake type of event.
Old 05-12-2019, 06:52 PM #4
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Pink Milk Shake ??
plcfcng is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 07:22 PM #5
Originally Posted by plcfcng View Post
Pink Milk Shake ??
Nope. Clean trans fluid and the water is just gone - looks like it's sprayed over the top of the engine, passenger side of the manifold
Old 05-12-2019, 07:59 PM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
how about the 2 coolant lines that go thru the throttle body? they are attached and no cracks?
it's very strange to just lose all the coolant and have it spray out... something must be cracked?
Old 05-12-2019, 08:28 PM #7
I just filled it with water and started it and let it ran, nothing is leaking anywhere!
I suspected coolant lines around the throttle body, I will take a closer look
Old 05-12-2019, 08:41 PM #8
Both the engine oil and transmission fluid are clean, I just had those flushed and changed a month ago.
I suspected transmission fluid/coolant lines, broken or maybe loose
Old 05-12-2019, 08:45 PM #9
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Coolant lines around the throttle body can't leak transmission fluid.
Are you sure it's transmission fluid?
Dexron automatic transmission fluid doesn't really have a smell to speak of.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 05-12-2019, 09:02 PM #10
Doesn't really smell, it looks exactly like what is on the trans dipstick. That's why I thought it was transmission fluid
It was just Spring out of the back of the engine area, like above where the transmission and engine bolt together
It's a slight reddish color,slick like oil
Old 05-12-2019, 09:17 PM #11
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
toyota red coolant
Old 05-12-2019, 09:19 PM #12
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
right I'm assuming it's toyota red coolant.
dude ATF stinks bad at least to me.
I mean radiator is empty? trans fluid is good and full? this makes me suspect coolant 100%.
Old 05-12-2019, 09:30 PM #13
Trans fluidd is full so was the engine oil, radier empty
But it is definitely oily
Old 05-12-2019, 09:34 PM #14
I flushed the radiator about a year ago and used what was recommended, however I'm pretty sure it was green
Old 05-12-2019, 09:45 PM #15
So I just check the transmission fluid, what is leaking is 100% transmission fluid, the water in the radiator is also missing
I had green coolant in her this time
The transmission fluid is super clean and as you'd imagine just slightly low. So that's what I have, transmission fluid spewing from what looks to be the back of the engine above or on the upper side of the transmission and missing water
appears , coolant , fluid , radiator , transmission
trans fluid and coolant mixing. wildcar 3rd gen T4Rs 25 01-15-2022 10:34 PM
Engine Coolant and Trans Temps DMX512 4th Gen T4Rs 17 12-27-2019 07:36 PM
Normal Coolant/Trans temps? tenro1 3rd gen T4Rs 10 04-03-2014 11:54 AM
2004 4runner V-6 Coolant & Trans? mac777daddy Maintenance/Detailing 5 06-22-2010 09:15 AM
DUMPING XREAS - Toytec Ultimate or OME?? East Bay Runner 4th Gen T4Rs 18 11-08-2009 11:30 AM
