Originally Posted by Drew76
When I experienced the rear end getting squirelly over bumps it was because one of the rear struts had rusted out and was no longer attached to the top mount. Either way it can be fixed without lifting if you don't want/need a lift. Did the mechanic get under it to do an inspection? I would check to make sure everything is where its supposed to be, tight, and check the condition of the struts, rear control arms/panhard bar and bushings etc and go from there.
thanks for your reply,
Yup, he put it on the hoist to make sure everything was hooked up and we didn't have something busted or disconnected underneath. There didn't seem to be. This guy is pretty good and doesn't try to sell a bunch of un needed stuff. Just to be sure I'll take another look under there later this week.
