Old 05-13-2019, 08:28 PM #1
mforce mforce is offline
mforce is on a distinguished road
High mileage oil leaks
I’m repairing my daughters 2000 4runner with 235,000 miles. Pulled the motor to fix the oil pan and rear main leak as well as valve covers since now we see those are leaking around the grommets. My question is what is the little bearing on the back of the block right above the rear main seal? Looks like oil is coming out of it. Also it hard to tell how long ago the timing belt was put on. It is a German belt I think it’s continential belt. I just want to do this once! Toyota 4Runner is no rust in great shape.
Sold; 98 4Runner Limited, OME 883's w/Bilstein 5100, Downey 3" rear springs w/Doetch Tech & Daystar 1.25" spacer, Cornfed 1" diff drop, Tundra 231mm brake upgrade, Tundra wheels/tires, Tinted windows, more goodies being added. Not quite to 200,000 miles club yet!
mforce is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 10:18 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
this thing?
I have wondered about it as well... never seen one leaking
parts diagram lists it as 9025010113
STRAIGHT (FOR TRANSFER CASE); STRAIGHT(FOR CLUTCH HOUSING SET); STRAIGHT(FOR END PLATE); STRAIGHT(FOR TIMING GEAR COVER SET); STRAIGHT(FOR TRANSMISSION SET).
Old 05-14-2019, 05:50 AM #3
Yes that little ball bearing thing. Mine has a little oil coming out.
Old 05-14-2019, 10:43 AM #4
nobb nobb is offline
nobb is on a distinguished road
What is that thing? I never noticed it when doing my rear main seal.
nobb is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 12:03 PM #5
Its a plug for an oil passage. It shouldn't leak! They are pressed in at the factory after machining/cleaning and shouldn't ever need to be removed (unless you are having major block work done).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-16-2019, 01:19 PM #6
Maybe the oil around mine if from another leak causing it to puddle. I have elected to replace a lot of items now the motor is out. Replacing valve cover gaskets,grommets,pcv grommet/valve, half moons, plenum gaskets, timing belt and complete kit with water pump, rear main seal and oil pan gasket. Oil pan and rear main was leaking thus the reason for pulling the engine to do the work. I figured since it was out might as well do the timing kit. I have a job ahead of me.
Old 05-16-2019, 03:09 PM #7
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@mforce I would do the hoses o-rings and internal cleaning of oil cooler while engine is out, did'nt see on to do list.
4runner , belt , main , oil , rear
New to me high mileage 3rd gen ASUMTNEER 3rd gen T4Rs 16 07-11-2016 03:51 PM
Will switching to synthetic in high mileage cause oil leaks in the future? jdotlim 4th Gen T4Rs 11 04-29-2016 01:27 PM
To buy low mileage or high mileage, that is the question DDeezenuts 3rd gen T4Rs 21 01-08-2016 03:22 PM
High mileage? MacGyver1979 Classic T4Rs 12 04-11-2014 04:36 PM
high mileage scd99 3rd gen T4Rs 1 07-20-2013 03:33 PM
