Originally Posted by mforce
I’m repairing my daughters 2000 4runner with 235,000 miles. Pulled the motor to fix the oil pan and rear main leak as well as valve covers since now we see those are leaking around the grommets. My question is what is the little bearing on the back of the block right above the rear main seal? Looks like oil is coming out of it. Also it hard to tell how long ago the timing belt was put on. It is a German belt I think it’s continential belt. I just want to do this once! Toyota 4Runner is no rust in great shape.
this thing?
I have wondered about it as well... never seen one leaking
parts diagram lists it as 9025010113
STRAIGHT (FOR TRANSFER CASE); STRAIGHT(FOR CLUTCH HOUSING SET); STRAIGHT(FOR END PLATE); STRAIGHT(FOR TIMING GEAR COVER SET); STRAIGHT(FOR TRANSMISSION SET).
