Originally Posted by VernySanders
Does anyone have an extensive list of part numbers for the pre bent hoses, or can anyone point me to a thread on here where that info is listed / a company that makes these? I was thinking about ordering 15ft of silicone hose but then I realized that 90% of the hoses are pre bent. Pesky Toyota. I know I dont absolutely need the bent lines but it will look cleaner with the OEM supplies.
I just went to o'reilly's and got 10' of different sized hoses. they radius just fine and IMO silicone is way overkill for these engines. I run a supercharger and I have never found a reason to go silicone. normal vac hoses seem fine.
you will want 3mm,5mm,7mm if I remember correctly.
otherwise I compiled a list a while back and I know the hose on the back on the air intake that goes to the drivers side head... I can't find a part number for it. sure it exists I just was never able to locate it.
I think once you add up the price for these you will head the generic route, hope it help?
9541110630 HOSE, FUEL, NO.1 (FOR CHARCOAL CANISTER) 2x on this one same part is used in 2 spots
9044512284 HOSE(FOR AIR PIPE)
1734362110 HOSE, NO.3(FOR IDLE-UP)
1730362020 PIPE SUB-ASSY, AIR, NO.1
1734162060 HOSE, AIR, NO.1
1734262080 HOSE, AIR, NO.2
1734362080 HOSE, AIR, NO.3
2382762030 HOSE, VAPOR FEED
1730875010 HOSE, VAC - super small skinny guy for vapor pressure sensor
9099992002 HOSE,VACUUM - evap canister OUT to inta
1226162050 HOSE, AIR, NO.1 - this is up on the air pipe before the throttle body
