Old 05-15-2019, 03:04 PM #1
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
NEW ALUMINUM Koyo Radiator for 3rd Gen Toyota 4Runner - VH010665N
Koyo is proud to introduce an all-aluminum performance radiator for the 1996-2002 Toyota 4Runner (3rd Generation). This radiator, part number VH010665N features Koyorad's NFLO triple pass technology which directs coolant in three directions through the radiator. Internal partitions are strategically placed to promote complete core coverage for improved efficiency over the OEM style single pass radiator configuration. In addition, the core thickness has been increased to 36mm, a 44% increase over the OEM unit and utilizes Koyorad’s high density tubes and fins to boost the vehicle’s heat capacity and endurance under extreme use.
Factory fans, AC condenser, OEM coolant hoses and OEM mounting provisions are retained, requiring no modifications. Koyorad’s advanced engineering and design methods, impeccable TIG welds, proficiency in furnace brazing, and triple pressure testing for quality has earned their excellent reputation in performance cooling worldwide.
Purchase Info - Use links below, enter code T4R for discount.
Radiator - VH010665N
Radiator Cap - SK-C13
This radiator separates the transmission cooler from the radiator. If equipped with automatic transmission, your 4Runner will require an external transmission cooler (not included).
Features:
Includes high quality, OEM style side mounting brackets
NFLO Triple Pass Technology
36mm High Density Hyper Core
All-aluminum radiator construction
TIG Welded and furnace brazed for longevity
Billet aluminum filler neck and drain plug
Compatible with OEM fans, hoses and mounting provisions
Triple pressure tested during manufacturing process
Special Notes:
If equipped with automatic transmission, vehicle will require external transmission cooler (not included).
Requires Koyorad # SK-C13 or equivalent cap. OEM radiator cap is not compatible.
MSRP $492.00
KOYO Part# VH010665N
Applications:
1996-2002 Toyota 4Runner 2.7L and 3.4L (3rd Generation)
UPC: 847839016921
Box dimensions: 32” x 8” x 31”
20 lbs.
Availability: Now accepting Pre-Orders - First shipment arrives mid May 2019.
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 03:25 PM #2
DaMonkey's Avatar
DaMonkey DaMonkey is offline
DaMonkey will become famous soon enough DaMonkey will become famous soon enough
DaMonkey's Avatar
Stock height? With that cooling capacity would be nice to be above frame rails for proper aftermarket skid clearance.
Just curious... (Iím a nerd)... any info on what the NFLO multiple direction flow actually does for cooling or why better than conventional triple core aluminum?
Itís nice to plug n play tranny if you have auto, but I like giving that capacity to coolant bc if you doing this radiator youíre all in anyway. Looks nice. Good luck w it.
rock beats scissors. zip ties beat clips.
www.maluna.com - Scott
DaMonkey is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 03:41 PM #3
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is just really nice TonyB66 is just really nice TonyB66 is just really nice TonyB66 is just really nice TonyB66 is just really nice
TonyB66's Avatar
With it being thicker (44%) and no dedicated real estate for an auto transmission cooler, what is the coolant capacity? I imagine a fair amount more...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 05:36 PM #4
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough
Real Name: Werner
Pretty priceyyyyyy but hey. Im just a 23 year old college student anyways. Im looking at the Liland global all aluminum OEM replacement that is plug and play for auto trans. Rock auto had it for $150 but they sold out so Im going to have to go with CarID for 200, free shipping though.
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 07:28 PM #5
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a jewel in the rough eimkeith is a jewel in the rough eimkeith is a jewel in the rough eimkeith is a jewel in the rough
Official Vendor
eimkeith's Avatar
If this were the short core (2.4 manual taco) it would be a total winner over existing options!
(short is where it's at)
separating the trans cooler is a solid idea though - kudos to koyo for having the wherewithal to do so.
keith
'96 SR5 - 3.4/5spd
check out the stuff I make
eimkeith is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 08:06 PM #6
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about
although a cooler for the tranny in the radiator...for this "new " radiator..being not in the radiator might be good for you folks down south...the radiator is also a pre-heater for the trans for us cold weather people...some days im lucky to hit above 30 in the winter
tranny fluid too cold is almost as bad as too hot
and the price is kind of up there....where a champion has the trans heating/cooling function
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 05-15-2019, 09:23 PM #7
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
Would have loved to seen this come to market ten years ago when I was changing mine out. I would have thought Koyo could have made more $$$ doing such.
COO?
Who will be the member to post the first pics?
Considering I have never had overheating problems and am seeing now a constant 188f thanks in large to finally expunging almost all the bubbles in the coolant, I will pass.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 10:13 PM #8
culiced culiced is offline
culiced is on a distinguished road
welp, i just bought an OEM radiator
culiced is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 05:10 PM #9
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz has a spectacular aura about JWaldz has a spectacular aura about JWaldz has a spectacular aura about
Moderator
JWaldz's Avatar
Real Name: Waldo
Champion's aluminum rad for the 3.4 tacoma is shorter.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | RMRacks | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 05:52 PM #10
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
yep, that's the one I have, but I'd have more confidence in a Koyo version.
keith
'96 SR5 - 3.4/5spd
Old 05-16-2019, 06:30 PM #11
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
I don't see why Champion would have lesser reputation than Koyo?
Old 05-16-2019, 06:37 PM #12
eimkeith's Avatar
Official Vendor
Official Vendor
eimkeith's Avatar
there've been a number of failures over on TW recently. hit or miss, it seems.
keith
'96 SR5 - 3.4/5spd
Old 05-16-2019, 06:40 PM #13
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice sleepydad is just really nice
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
the name Koyo sounds like it would cool in a more Japanese way?
Old 05-16-2019, 07:09 PM #14
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
hmmm
Mine seems to be going strong (knock on wood).
FWIW, I bought an OEM Toyota Rad to replace my original some years ago and it failed in 3 years. Then I got the Champion. Been happy since.
Old 05-16-2019, 07:22 PM #15
Official Vendor
Official Vendor
Just curious... (I’m a nerd)... any info on what the NFLO multiple direction flow actually does for cooling or why better than conventional triple core aluminum?
It’s nice to plug n play tranny if you have auto, but I like giving that capacity to coolant bc if you doing this radiator you’re all in anyway. Looks nice. Good luck w it.
N FLO has to do with the flow (or "pass") of the water, where double/triple core references the amount/orientation of layers of tubes.
This KOYO is a double core, triple pass radiator (Image says dual, but it its a 3 pass in that is goes down, up, down.
Dual vs Triple Row Cores
oem , radiator , transmission , triple , vh010665n
96+ 4Runner Radiator - Koyo Brand - $80 P/U Preferred in Chicago DudeMan For Sale: T4R Items 5 06-17-2013 04:48 PM
Koyo Radiator or OEM?... Supermoney 3rd gen T4Rs 4 03-06-2013 07:30 PM
Koyo radiator cap? Dark Lord 3rd gen T4Rs 1 04-16-2012 11:25 PM
where to buy koyo radiator WHORERUNNER 3rd gen T4Rs 2 06-23-2011 11:23 PM
Will this KOYO radiator work as an OEM radiator as far Gavin S. 3rd gen T4Rs 9 06-08-2010 11:04 PM
