05-15-2019, 04:10 PM
Need some rust advice before buying (pics included)
Hi all,
I am talking to a dealer with a ‘01 SR5, with incredibly low mileage (58k). I’ve asked for some pictures and received the below. I’ve only ever owned a 4th gen, so hesitant with the older trucks. What do you think? This is all he can get before sending it off for safety inspection (trade-in). Thanks
05-15-2019, 04:52 PM
Real Name: John
Real Name: John
Originally Posted by Juice88
Hi all,
West coast guys will have a heart attack looking at that. Just from that one picture I'd say it's good. No actual deterioration of the metal (well a little on the body mount bracket). No flaking. Rust only on the welds. Like to see a picture of the inner frame by the muffler and the rear of the differential housing.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
05-15-2019, 05:17 PM
Get more pictures..under and inner
05-15-2019, 05:33 PM
Real Name: Werner
Real Name: Werner
its got 58k miles lol just get it. thats not bad at all.
05-15-2019, 06:07 PM
Real Name: Eddie
Real Name: Eddie
Man, that gives me the heebie jeebies.
Here's a pic on the underside of my '01.
Rust will get your T4R before miles do.
I'd buy one out here (and with higher mileage) and IMHO, it'll be better all the way around.
How much is the asking price?
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
05-15-2019, 06:41 PM
Good luck,
Eddie
Shhhh, us west coasters are not allowed to chime in on rust threads.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
05-15-2019, 07:16 PM
Good luck,
Eddie
$9,900
Going to try and get more pics underneath as noted above. Thanks for all the input. And tbh I haven’t seen much pop up on the west coast, but I’m keeping my search radius open
05-15-2019, 07:33 PM
For a CT vehicle - that is barely surface rust. Easily taken care of... crazy low miles though! I'd buy it for $9,000 without a second thought.
Good luck.
05-15-2019, 08:04 PM
That frame looks beautiful! As long as the rest looks that good and the rear axle housing is ok it probably good at about $9000 at a dealership in CT fully detailed of course.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
05-15-2019, 08:07 PM
We're just jealous
05-15-2019, 08:33 PM
Real Name: Eddie
Real Name: Eddie
After sales tax and such me thinks you'll be close to 11 large, right?
I should have added to to my first reply that buying one here to get rust free and then coating the underside with WD-40 or Fluid Film will ensure your frame, etc outlasts the mechanics of your T4R.
Good luck,
Eddie
$9,900
05-15-2019, 08:47 PM
Real Name: Mark
Real Name: Mark
Good ones can be found in third coast area less than western prices.
05-15-2019, 09:07 PM
That frame looks manageable, but I'm not sure if I'd pay $9,900 for it. That money will get you into a 4th gen V8. I highly doubt anyone else will pay that price.
if you're keen on getting this truck, make them a lower offer.
05-15-2019, 09:18 PM
If you do decided to buy it, I have a solid way to treat the current rust and prevent it from rusting further.
Step 1. Wire brush wheel on an angle grinder ( a drill would also work but it will take a lot longer to accomplish the desired effect).
Step 2. Once all of the heavy rust flakes are completely removed. brush or roll on Corroseal (water based rust converter) over the entire rusted area. It is milky white at first and dries to a black, paint-able service.
In my experience of using this on under carriages its best to pour it into a small container and use a little at a time.
Once the Corroseal has completely cured you can leave it alone or you can paint over top of it to prevent any further damage.
Personally, I used Line-X over top of it to "bullet proof" the frame and under carriage.
2017 4Runner SR5 Silver
05-15-2019, 10:24 PM
Also be aware that the low mileage may not be a good thing. Was the oil changed on a regular basis ? You may be buying some sludge as well.
No need to ask how I know ..
Also check the passenger side rear control arm mount, they will rust before the drivers side in my experience . Looks as if they sent you the drivers side only.
My first one bit the frame on that side, passenger side was a mess, drivers side not as much. Had to send it to pasture,
My second runner had the same situation , passenger side had more issues, tho it was very minor, I saw it and adressed it right away.
East Coast Runners......
$9900 is a little high, I paid 6500 for my second one. Higher milage , No sludge tho unlike my first 88K sludge machine, less rust tho I did do preventive repair on the passenger side bracket.
