I’ve reached the end of my sanity...
So it’s been 4 days of trying to get this 4Runner going.. I know what the issue is but can’t get it to work correctly.
I had bad shifter bushings which caused significant wear on the Shift Control Lock
I’ve repaired the shift control lock but when assembling it binds up and won’t move. From what I can tell I have everything together correctly but the button you push down to shift into N, R, D, 2 and L is stuck!
I took everything apart and replaced bushings and reassembled with success but when trying to put the Shift control lock back in the button to shift won’t go down far enough to remove from park
I don’t know what’s wrong and I’m losing my mind
