Old 05-15-2019, 10:11 PM #1
Wallrunner Wallrunner is offline
Wallrunner is on a distinguished road
Shift Control Switch please help!
I’ve reached the end of my sanity...
So it’s been 4 days of trying to get this 4Runner going.. I know what the issue is but can’t get it to work correctly.
I had bad shifter bushings which caused significant wear on the Shift Control Lock
I’ve repaired the shift control lock but when assembling it binds up and won’t move. From what I can tell I have everything together correctly but the button you push down to shift into N, R, D, 2 and L is stuck!
I took everything apart and replaced bushings and reassembled with success but when trying to put the Shift control lock back in the button to shift won’t go down far enough to remove from park
I don’t know what’s wrong and I’m losing my mind
DDC4-D1-C8-B118-46-FD-9253-1-D6939-F67746
Wallrunner is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 01:02 AM #2
4Reak Show's Avatar
4Reak Show's Avatar
I'm guessing a couple things: your interlock solenoid is either stuck or you don't have it plugged in. It needs power to activate to release the lock.
You also need key on and press the brake pedal to shift. That's what sends the command to activate solenoid to release.
To confirm its not a mechanical bind: remove small cover in console for shift lock override and insert a small screwdriver. You should be able to manual move the lock's linkage to shift gears.
Good luck.
Edit: are you trying to move it on a table out of the vehicle? Yeah that won't work... Needs to be installed and hooked up to power to activate.
Old 05-16-2019, 11:18 AM #3
Good luck.
Dude!! thanks a ton! I've been so stressed out trying to get this thing running it didn't even cross my mind it needed power to release. Ill try it when i get home
You're a life saver thanks!!!
Old 05-16-2019, 02:31 PM #4
4Reak Show's Avatar
4Reak Show's Avatar
Oh dang man. I was thinking that was too simple to be the cure... But I'll take it!
What's the saying? "Can't see the forest through the trees" something like that. We've all been there.
Post up if it works. You don't have to hard mount it back in to test. You should be able to just plug in the wires, turn the key to "on" and push the brake pedal. You should be able to see or hear the plunger actually click and then the button will travel properly.
Good luck
Old 05-16-2019, 04:49 PM #5
AntleredRuin AntleredRuin is offline
Real Name: Daniel
AntleredRuin will become famous soon enough
Real Name: Daniel
I can confirm that I had an 'oh shit' moment a few years ago because I forgot to plug mine in before I tested it. Indeed, nothing happened.
It's an anti-theft/safety feature.
AntleredRuin is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 11:04 AM #6
Good luck
It worked! not as quick as I hoped cause my battery was dead lol
thanks again for all the help!
Old 05-17-2019, 11:43 PM #7
4Reak Show's Avatar
4Reak Show's Avatar
Awesome! Take the easy ones when you can. Glad it worked out. I'd bet that's an oversight you'll only make once in your life.
button , control , lock , shift , won’t
Key stuck in ignition, Computer Shift Lock Control help! Tylersanders 3rd gen T4Rs 26 12-11-2019 02:30 PM
Fan control switch parkay Classic T4Rs 11 04-02-2014 03:43 PM
Temp Control Switch??? sup3rdav1 Classic T4Rs 0 05-10-2013 04:23 PM
Traction Control Switch A/V1 Classifieds - buy & sell (no commercial ads please) 2 09-10-2008 11:44 PM
Cruise Control revs high and won't shift correctly drewgarrett Classic T4Rs 0 06-01-2008 05:19 PM
