Old 05-16-2019, 10:25 AM #1
VernySanders VernySanders is offline
VernySanders is on a distinguished road
Elocker Bearing Kit vs Regular Bearing kit?
Is there truly a difference between these two? I rebuild diffs for a living and I'm looking online for a bearing kit, all I see if bearing kits that say for a 3rd gen w/o locker... so does anyone have experience with this? Or at a bare minimum are at least the pinion bearings the same because I'll just keep my side bearings and replace the pinion bearings
VernySanders is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 03:16 PM #2
96RedRunner will become famous soon enough 96RedRunner will become famous soon enough
Just purchased a Yukon locker master rebuild kit and gears from Randysworldwide.com.
They will answer all your questions.
Old 05-16-2019, 04:30 PM #3
I did a ton of research today and ended up deciding to go with east coast gear supply. Toyota 8" E-Locker Install Kit -MASTER - 27 Spline pinion cheapest price by far. With Koyo bearings as well. Randy's worldwide was running $445 east coast gear supply is $225 I believe.
Old 05-16-2019, 06:48 PM #4
Have done business at ECGS also I wanted Yukon gears over Nitro.
bearing , bearings , elocker , kit , pinion
Toyota Denso AC Compressor bearing and Idler bearing replacement nissanh 3rd gen T4Rs 20 11-07-2018 12:52 PM
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Inner cv shaft bearing,,differential bearing replacement razerface 4th Gen T4Rs 5 03-25-2018 09:27 PM
Fan Clutch Bearing Bracket: Replace bearing only? nobb 3rd gen T4Rs 0 05-17-2016 05:22 AM
help!!wheel bearing or carrier bearing or something else? sawguy 3rd gen T4Rs 7 05-06-2015 01:55 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
