05-17-2019, 12:10 PM
Location: Southern California (please don't hold it against me)
Real Name: michael
Real Name: michael
Head lights
Are there any problems using headlights from a 2000 4runner in a 1997?
05-17-2019, 12:23 PM
nope. easy swap. you'll have clear glass lenses rather than "frosted" glass lenses to boot.
2000 4Runner SR5 Sport
1998 Lexus LX470
05-17-2019, 12:46 PM
No problems. Enjoy your vastly upgraded headlights after the swap! Per @MTD, the 99+ use reflector optics to shape the light versus the Fresnel lenses that the earlier versions used, thus the vast difference in performance and appearance. Your brights should be *ahem* a LOT better.
Bilstein 5100 shocks and OME 2881/2906 springs; Tundra brake upgrade w/ SS lines front & rear; Big-3 electrical upgrade; Airaid intake.
05-17-2019, 07:13 PM
Real Name: Jerod
Real Name: Jerod
No issues, it's a great upgrade.
If you are looking at buying new, Rockauto has a great price on TYC headlights, when I bought mine there were just under $80 for the pair. Put in a set of high-wattage halogens (60W+, avoid the blue lights) and you'l actually have decent headlights that compare to normal cars!
05-17-2019, 07:35 PM
Real Name: Leon
Real Name: Leon
I did exactly that on my '97. It definitely improves the lighting, and the look is much cleaner.
Having said that, my lights still felt somewhat dim (I should be clear, I installed junkyard '00 lights, not brand new ones). So I frequently used my HID foglights to augment the headlights.
Then I upgraded the bulbs to OEDRO LEDs, and the light output improved tremendously. So much so, that I don't even see the HID foglights when I turn them on in addition to the headlights.
So that's a very good setup, IMO.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
05-17-2019, 08:01 PM
Real Name: Morgan
Real Name: Morgan
is fresnel the technical term for the fluting on the lenses? Learn something new every day
2010 SR5 Blizz Pearl- Borla cat back, Firestone ride rite, Huskyliners, Afe Cai, Urd MAF, Gobi stealth with ladder, 5100s, icon 2" rear, toytec 1.6" front, TC UCA, HAF custom sliders, hand hold light mod, Led interior, stock rims and BFG KO2 265/70 C, Arb CKMA12- slider tanks w/ couplers, BD S8 10", opt7 40", BD dome light led in rear hatch
05-18-2019, 12:42 AM
Real Name: Keith
Real Name: Keith
No. Fresnel lenses always are composed of concentric rings or ridges. Lenticularly fluted would most accurately describe the old headlight lens style.
More info:
Fresnel lens - Wikipedia
05-18-2019, 08:33 AM
More info:
Looks like you're right. Since I have a 99 I don't spend a lot of time staring at the earlier version headlights, however this link: Upgrade ’96 – ’98 Toyota 4Runner Headlights – Josh's World has a decent write-up of what OPs doing and has some good comparison photos.
05-19-2019, 01:25 AM
Real Name: Keith
Real Name: Keith
Were your TYC 99+ headlight assemblies with glass lens? And were they not any more flimsy than the OEM units? I ask because there is conflicting info on the web.
05-19-2019, 09:16 AM
Real Name: Leon
Real Name: Leon
I have not seen TYC headlights for the 4Runner, but I've use TYC lights for other vehicles, and while they were good from the standpoint of major components (housing, lens), their hardware always was inferior to OEM. And all the other aftermarket headlights I saw for the 4Runner had the same issue.
When I spoke to Daniel Stern about headlights for the 4Runner, he said the first thing he'd recommend is to get brand new Toyota headlights. Yes they are very expensive, but his point was that after 20 years, the surface of a used reflector becomes oxidizes and dusty, reducing reflectivity (and thus light output) tremendously. And he said to get OEM because none of the aftermarket brands have reflectors shaped as well as OEM.
05-19-2019, 06:38 PM
Real Name: Jerod
Real Name: Jerod
Yes, it does have a glass lens which is clear and bright. However, I have had issues with one of the lights that I eventually replaced (just outside of warranty). There's a ball joint like coupler that keeps one side of the light fixed for the adjustment spring and it popped out and I couldn't get it to stay in.
The OEM reflector does have a slightly better beam pattern. I've got a "hot spot" in the lower left section of the driver's side light, but it's not anything terrible. For what you get, being a fraction of the price of a new OEM unit, it's worth it. I could buy 4 of these lights for the same price as 1 OEM headlight assembly.
05-20-2019, 01:26 AM
Real Name: Keith
Real Name: Keith
Alas, It appears that Toyota USA sold out of all the newer, cool-design 99+ OEM headlight assemblies some time ago. They still have the pre-99 ones, however, which is what I went with.
To Mr. Stern's point, I noticed that the brand new OEM pre-99 headlight I installed was easily twice as bright as the 21-year-old OEM unit remaining on the truck, using identical bulbs. I see that the 99+ units are almost $400 from Amayama.
05-20-2019, 01:28 AM
Real Name: Keith
Real Name: Keith
Good to know...thx.
05-20-2019, 01:14 PM
Real Name: Leon
Real Name: Leon
I see quite a few 99+ headlights online for under $200 brand new. Like this - 81170-35300 - Genuine Toyota UNIT ASSY, HEADLAMP, LH
My original thinking was that for that kind of money, I'd rather do an HID retrofit. But since I'm not crazy about the looks of HID retrofits, I might end up going for the new OEM headlights.
05-20-2019, 03:28 PM
Real Name: Jerod
Real Name: Jerod
Yeah, $320+ for a set of OEM headlights is rediculous. That's why the TYC headlights are an attractive alternative. I could do a whole lot of other things with $320.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
