Old 04-02-2021, 06:13 PM #1
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
3rd Gen Rear Speaker Wiring
I took a break from writing code and decided to replace my amp and rear speakers. Point being, I'm no expert here.
I've seen other posts where the best answer I found was "a little soapy water" but it looks like I need to cut into the tape around the existing wires to even get in to the hole in the grommet so I could slide the speaker wire through.
Is removing that tape the best way to approach this and if so, what's the best material to replace it with when I'm done?
'96 T4R SR5 | 4WD | Auto | 199 TBU | 268k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 06:31 PM #2
My grandfather came to me in a vision - he was a Ford mechanic for decades.
For anyone else facing this - I removed the tape, got in there just enough with a wire coat hanger to give me a little room, put some vaseline on the end of the speaker wire and it slid right through.
Hopefully getting it into the door will be just as simple. And I imagine any sort of weatherproof tape would work.
Old 04-02-2021, 06:55 PM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I'd just use any decent self fusing silicone tape to re-wrap the wiring.
Skulking is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 05:45 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Any particular reason why you decided to replace the wiring? I have a small amp that pushes about 45W RMS to each speaker and kept the stock wiring with no issues. Toyota does use pure copper stranded wire.
326WHP 347TQ
existing , rear , replace , speaker , tape
Separating hatch and rear door speaker wiring without cutting? Kenamond Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-13-2021 08:46 PM
After Market Speaker Wiring DUBBZ_CEMENT_PRO 5th gen T4Rs 11 05-04-2020 04:21 PM
Rear speaker upgrade ( Need wiring diagram) S141995 5th gen T4Rs 6 05-31-2019 01:56 AM
Speaker wiring.... BHarv 4th Gen T4Rs 4 01-18-2016 04:56 PM
Front and rear speaker install using stock mounts and plug & play wiring yota_addict 3rd gen T4Rs 1 07-04-2015 03:08 AM
