Old 05-18-2019, 11:13 PM #1
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
Gauges and AC not working. Blown fuse, replaced fuse, blown again. What do?
The gauge cluster stopped working, meaning every gauge arm is at the bottom.
I found it to be the gauge fuse to be blown, so I pulled out my spare fuses and replaced it, turned the key and the gauges didn’t work so that fuse blew immediately, too.
It’s late at night now so I was planning on going to an auto store in the morning.
TIA.
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 05-19-2019, 12:03 AM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
TIA.
Your ac compressor is messed up. Disconnect the ground on top of the compressor so it does not try to lockup the stator/clutch. It could also be the bearing on the front of the compressor but I would expect some major squeaking because the compressor is locked up.
If the stator inside the compressor is messed up that is the fuse and it’s shared with the gauge cluster.
Old 05-19-2019, 03:38 AM #3
4Reak Show's Avatar
4Reak Show's Avatar
Damn
Old 05-19-2019, 08:03 AM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by 4reak show View Post
i don't know if i'd used the word stator. I'd prefer magnetic clutch. Likely a short there. You can likely replace the clutch, bearing and pulley as a set without having to discharge ac. You'll need a feeler gauge and specs for the air gap for the hub-to-clutch spacing.
Figure out the short first, and if you plan on tackling the ac clutch post here and i can try and walk you thru it.
Good luck.
stator sub-assy, magnet clutch 884112a030
ಠ_ಠ
Old 05-19-2019, 10:18 AM #5
blairracd's Avatar
blairracd's Avatar
Would you be able to take a picture of that for me, please? The ground that is.
RIP my ‘96.
Old 05-19-2019, 10:37 AM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's not really a ground... it's 12 VDC+ but it's causing your trouble. there is only one electrical connection on the compressor, that is the one.
https://i.imgur.com/HLNJA90.jpg
if your looking at getting running again?
#1 unplug that grey plug, it's in a biach of a spot.
#2 this step is optional but probably a good idea: either remove the AC belt or cut it if everything is rusted up.
The only reason I say cut it is because you will have to replace the compressor (most likely) it's probably cheaper to re-build it but re-man denso's are pretty cheap now days. you should probably get a new belt anyways if you replace compressor and pulley. belts are pretty cheap also and just cutting the old one off is super easy. others here will disagree with me but... I'm pretty lazy when it comes to belts.
Old 05-19-2019, 10:56 AM #7
blairracd's Avatar
blairracd's Avatar
Could you take a picture a little further away so I know if I have the right one?
RIP my ‘96.
Old 05-19-2019, 11:34 AM #8
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
it's right below the power steering pump on the passenger side.
it's hard to take a picture because you can't see the connection unless you get right down into the engine on the passenger side.
in the picture from before you can see the AC compressor pulley where the belt would go. mine is off because I'm working on a electric fan conversion right now... but you have to go at it from the passenger side. depending on the year of your truck the power steering might look a little different? what year is your truck?
Old 05-19-2019, 02:05 PM #9
blairracd's Avatar
blairracd's Avatar
1999.
After one stop this morning it barely started and it’s now running extremely rough, windows and locks and lights are all dead now.
I’m in another state at a gas station after limping off the highway. So I’m really scared to turn it off.
RIP my ‘96.
Old 05-19-2019, 02:11 PM #10
blairracd's Avatar
blairracd's Avatar
imgur: the simple 404 page is this the plug?
RIP my ‘96.
Old 05-19-2019, 02:27 PM #11
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
you will need a flashlight to see it, it's probably covered in a layer of gook. it's a biach to get your hand in there but it's there. follow that wire I put the arrown on.
Old 05-19-2019, 05:23 PM #12
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
1999.
It sounds like your alternator is not charging and your 4runner is running off the battery.
As for your other problem, the 10 amp gauge fuse in the driver's side junction box supplies power to the field coil in the heater relay and the fan switch supplies the ground. When energized, the heater relay supplies power from the 100 amp alternator fuse to the 50 amp heater fuse which powers the blower motor. The A/C compressor field coil gets it's 12V B+ from the 10 amp A/C fuse in the engine compartment junction box. Your problem is more likely a short to ground near the ECJB.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 05:55 PM #13
Amateur Amateur is offline
Amateur is on a distinguished road
Thanks a bunch sleepydad!! I have the same problem and it would likely have been a long time before I got to the AC compressor while looking for a short in the gauge cluster circuit.
Amateur is offline   Reply With QuoteReply With Quote
blown , fuse , gauge , gauges , replaced
Blown fuse? KENGNJ 5th gen T4Rs 2 01-26-2018 06:02 PM
Blown fuse (I think)? DoctorJest Classic T4Rs 3 08-15-2014 08:46 PM
Blown Fuse or Blown ECU? pcr777 3rd gen T4Rs 3 04-23-2013 01:40 AM
A/C fuse blown jbcampbell21 Classic T4Rs 1 09-22-2010 08:30 PM
