Old 05-19-2019, 07:58 PM #1
Gymoutlaw Gymoutlaw is offline
Real Name: Will
Gymoutlaw is on a distinguished road
Real Name: Will
Question ABS pump help
Hopefully someone can shed some light on this issue. I was getting a sinking pedal and replaced every component in the brake system with new OEM parts over the past two months and still getting a sinking pedal. After doing research on here I found that the ABS pump was most likely the problem even though there was no ABS lights on dash. I bought a used pump off eBay and replaced it this morning. Brake seemed to get stiffer, but after looking under the hood there is fluid coming out of every fitting on pump block?? See picture
Any clue how this is possible?? All fighting are plenty tight.
ABS pump help-9529e681-d2d9-45b2-b63b-06e351c5be14-jpg
Gymoutlaw is offline   Reply With QuoteReply With Quote
Old 05-20-2019, 01:54 PM #2
Real Name: Will
Real Name: Will
Bump
abs , brake , pedal , pump , replaced
possible oil pump? dcnaz 4th Gen T4Rs 22 12-13-2014 01:09 AM
ABS Pump? why do you gotta' pump every 5 seconds? infamousRNR 3rd gen T4Rs 5 01-17-2014 10:32 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
12v Air pump Falls Engines / Suspension / Wheels / Tires / Audio / Accessories 7 06-23-2006 04:20 PM
