Old 07-17-2019, 04:05 PM #1
wettRunner's Avatar
wettRunner wettRunner is offline
Real Name: Wettlin
wettRunner is on a distinguished road
wettRunner's Avatar
Real Name: Wettlin
Single clunk when changing direction NEED HELP. (99 4wd)
When I'm backing into a parking spot, i'll turn the wheel and hit the brake, and a loud pop/ clunk happens. Loud enough for people nearby to look over.
I've replaced most of the front end including: (5k miles ago)
- LBJ's
- LCA's
- UBJ's
- UCA's
- Sway bar end links
- ITRE's
- OTRE's
- Steering rack bushings
- Springs
- Top plates
- Shock absorbers
I cant for the life of me think of what it could be.
I can feel it happen on the floor and, in the steering wheel, and it sounds like a metal on metal clunk.
It usually happens once every time I drive, and its always at very low speeds when I change direction. It doesn't happen every time either.
Any advice or discussion is welcomed and appreciated.
Thank You.
wettRunner is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 05:45 PM #2
hamsandwiches hamsandwiches is offline
hamsandwiches is on a distinguished road
Bad half shaft. Can you hear it on a particular side?
zoinks! there's scoob
hamsandwiches is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 07:40 PM #3
wettRunner's Avatar
Real Name: Wettlin
wettRunner's Avatar
Real Name: Wettlin
It’s really hard to specify which side it’s coming from. I was thinking cv axles but I figured the popping would be consistent. I’ll try to record it somehow.
Old 07-18-2019, 01:15 PM #4
KamKoz KamKoz is offline
Real Name: Kameron
KamKoz is on a distinguished road
Real Name: Kameron
Check the torque on your LCA cam bolts. I have had a very similar sound coming from my driver side that ended up being a loose cam bolt after alignment when my JBA UCAs were installed. Took a good month or two and numerous trips off road before I heard it.
'99 4Runner Limited 4WD 3.4L @200k -- Imperial Jade Mica -- 265/75R16 Milestar Patagonia M/T. OME 881, LC coils/shocks -- ARB Rear Air Locker -- JBA Upper Control Arms
KamKoz is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 01:28 PM #5
wettRunner's Avatar
Real Name: Wettlin
wettRunner's Avatar
Real Name: Wettlin
Awesome. I've had two alignments done and my front wheels are cambered positively pretty bad.
I got greaseable cam bolts so ill check that they are greased and torqued.
Thank you for the reply.
Old 07-18-2019, 11:34 PM #6
Gary Blake's Avatar
Gary Blake Gary Blake is offline
Real Name: Gary Blake
Gary Blake is on a distinguished road
Gary Blake's Avatar
There is also a good chance it is the slip yoke in the rear drive shaft binding, this can cause quite a loud bang from the rear end under the circumstances you describe.
Simple fix, four bolts to detach the driveshaft from the rear diff, pull the splined section apart clean and re-grease. Just need to remember to mark the two halves so they go back in the same alignment and to remove the grease nipple to release the suction or you will never get the two halves apart.
@mtbtim (Tim the Toolman) has a video on the fix
Slip Yoke Binding Fix
Gary
2000 SR5 4 Runner, 3.4, 5spd, 4WD
Shrockworks front & rear bumpers & sliders, Warn VR10,000S, Optima Yellow Top, Icon Uniball UCA
Toytec Ultimate Lift Kit (Soon to be replaced by Icon)
Method 305 NV Racing Wheels
Gary Blake is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 11:28 AM #7
redshift83's Avatar
redshift83 redshift83 is offline
redshift83 will become famous soon enough
redshift83's Avatar
I've had this happen too when my rear LCA bolt loosens up. For some reason the driver's side one gets loose after a bit of off-roading and I will get a clunk until i tighten it. It happens when starting off from a stop or switching to reverse/back to forward. It only does it once per direction or until the suspension is moved around and thus the pivot is freed up again. You may want to check all the control arm/ panhard bolts to rule them out.
10 4Runner Trail - Dobinsons IMS, Spidertrax, C4 Fab Lo Pro bumper, Prinsu full rack, etc.
91 Celica All-Trac - tons of mods
99 Miata -makes supercharger noises
83 CJ7 - 304 swap w/tbi, 33's, still broken
redshift83 is offline   Reply With QuoteReply With Quote
clunk , happen , loud , metal , wheel
LCA bolt torque without changing alignment? Front clunk. blefevre1 5th gen T4Rs 11 11-01-2023 02:55 PM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Changing gaskets when changing diffs/tranny fluids? ShooterMcGavin 3rd gen T4Rs 17 08-12-2014 02:22 PM
